Who uses the LV 3-in-1 Brass Marking Gauge *LINK*
CONGER - The Irish diaspora in Munich
>What is it like to use?
Is the blade a 'snap-off' blade?
Is the blade single-bevel or double bevel?
Any more comments?
Thanks in advance for your tips.
-g-
Lee Valley 3-in-1 Brass Marking Gauge
Re: Who uses the LV 3-in-1 Brass Marking Gauge *LINK*
Mike-in-Havertown
>Hello,
I use the 3 in 1 and I love it. The blade is the snap off type like in some exacto knives, but it is long enough that it will not snap in use (you only put one lenght in at a time). I have put it through some tough tasks and it has never broken.
The only down side is that when you are tightening the fence, it can move. Once you get the hang of the tightening it pretty much goes away.
The blades are easy to change out and they stay sharp, it is the best 12.00 you can spend.
Mike
I'm with Mike it's a good deal
Eric Hedberg
>My only nit pick is with tightening also. I wish it had a flat/groove down the top of the shaft with a set screw (non cup end) or pin going through the top of the fence. Then the fence might not rotate as I tighten it into position. The point of this design, I think, is function and great value. At this price, its hard to complain. Eric
Buy it you WILL use it.
Ernie Miller Topeka
>Good tool I like mine I don't remember having the problem that the others mention but I could be a little slow. I would also like to see changes made but they are differant from there's and a fitted box would also be great to hols the extras that are not in use. Guess I will have to do that myself.
Jim in Burlington Ont.
Jim in Burlington Ontario
>Mine get's a little use. Prefer the titemark it's easier to adjust.
Is the blade single-bevel or double-bevel?
Double
Pam Niedermayer - Austin, TX
Thanks Pam...
