Plane building failure
Matti Kuikka
>I thought that other beginners might benefit of a story of non-success for a change and maybe learn through my mistakes.
For background; I have currently in use following self-made planes: a scrub with a curved Hock blade, a jack with a Hock blade and a smoother with a small japanese blade. I made the first planes about 3 years ago a'la Krenov but scrapped them after pin failures. Those above are made by gluing sides with grooves for wedge and blade to a centre in two pieces, which method I find to be easy and sufficient to my needs as I prefer wooden planes. All serve as intended.
This time I got a really nice thick blade without a chipbreaker from Rolf Schmid from Germany (A2 cryogenically treated and sharp)and I thought I'd try a low angle bevel up after reading so much about them. It just doesn't work on endgrain as meant.
First the bottom behind the blade bulged a lot though the center is made of ebony. After flattening the bottom, the mouth was too large so I made a shimmy. Next I found that the nose should be much longer to start the cut well and level.
It's VERY difficult to set the blade though I'm used to woodies, probably due to the thin seat. I have a wider japanese plane that outperforms this coming and going on endgrain any time and is easier to use IMO.
So I'll make a try plane with the nice blade as I originally intended and write a loss with couple of pieces of nice wood and a gain in learning and a nice time in the shop well spent.
Constructive comments are naturally what I hope for.
Matti Kuikka
