Another workbench question
Kelby
>I am preparing the end caps for my workbench and I have a question.
My top slab is 23" wide, made from laminated 6/4 hard maple that is 3" thick. The endcaps are walnut. I have made a tongue-and-groove joint between the caps and the slab. I was planning to hold the endcaps to the slab with lag bolts.
I would like to use dovetails to join the ends of the end caps to the face of the bench and to the outside board on the tool tray. Do I glue the dovetail joints? If I do so, how will that allow for movement across the top?
Landis' book shows similar dovetails on Frank Klaus' bench, so I read how he does it. Landis says that Frank Klaus simply glues his endcaps onto the slab, contrary to popular wisdom, and that he hasn't had a problem with splitting due to wood movement. Has anyone else tried this?
Thanks,
Kelby.
