Lapping long planes
Lapping long planes
Lapping long planes
John Todd
>Read the discussion on Jointer Problems a couple of days ago and it brought up a question I have had for a while. While I make some effort to be sure that my planes have flat soles. My Clifton #7 conserns me. It is pretty good, but could use a little flatening. I use thick glass and wet/dry sandpaper on most planes with good enough results for me. How do you flatten longer planes, within the limits of reasonably available equipment? Or not to worry and not hold it to the same standards as a #4 smoother. Thanks for any insights.
Re: Lapping long planes
Not trying to be a Heretic here�
Scott Burr in Ben Lomond CA
>But, this is a good job for the top of your table saw of finger eatin� jointer.
Get a long belt sander belt and cut it down the seam attach to the table and go to town.
It might not be needed. All that matters is the toe, front and back of the mouth and the tail are all in line.
Frank D. in Montreal
>I went out and bought a piece of 1/2" glass, 6" by 30". Not the most economical solution, but once you have it you can lap any plane, even use it for scary sharp. I don't want to put water near my TS.
2�
Jim in Burlington Ont.
Jim in Burlington Ontario
>I use a old glass coffee table top that I picked up at the reuse center for a buck. I have tried sandpaper and carbide powder. Carbide powder mixed with oil seems to give me the best results.
Re: Not trying to be a Heretic here�
Bob Hutchins in central Texas
>Howdy Scott!
What grit belt do you use? I've got a coupla planes I want to flatten and the TS top sounds like the way to go.
BobH
paul womack
>You may struggle to find a rigid reference surface as long as your Clifton #7 that is as flat as your Clifton.
As size increases, flexibility of the reference becomes an issue. Trying to support glass on mdf to avoid this problem replaces the flatness of glass with the flatness of mdf, which defeats the object.
Similarly, power tool surfaces are flat enough for their working purpose, not neccessarily as reference flats.
Unless you buy a granite surface plate.
BugBear
Re: Lapping long planes - long response *LINK*
>Hi John
There are a number of options from which to choose when seeking to flatten the sole of a plane, principally those of scraping and lapping.
As has been stated, the important areas to level are the front and rear of the plane, and the front of the mouth.
Bubbear has written a tremendous article on the art of scraping, and it is a must-read as it will open you eyes to the difficulties and dangers of lapping plane soles. The link is below.
Personally, I have ascribed to lapping in the past, and continue to do so under conditions that are unsuited to scraping. Such as the Stanley #7 Type 11 I am working on. The sole of this plane has a low spot in front (and, less importantly, at the rear) of the mouth, which means that the whole sole has to be flattened. Scraping was not an option.
Today I received Zirconion Oxide belts (80 and 120 grit) following a recommendation of Bugbear, having experienced the futility of using ordinary sandpaper. The problem is not that it wears out too quickly, just that it does not remain sharp enough for a plane the size of a #7. This may sound tautological but it is easy to demonstrate in practice: there is a point where one can still lap a #5 while a #7 does not cut at all. This has to do with the downward pressure on the lapping surface reducing in proportion to the increasing size of a plane. Consequently, the larger the plane, the more sandpaper you will go through. Unless ... you use Zirconion Oxide sanding belts.
Don't use a cast iron tablesaw surface on which to do this. Not only is it not flat enough, it is too high to achieve sufficient downforce.
My lapping table is a 10 mm thick sheet of float glass that runs 1m long by 300 mm wide. It rests on a 18mm thick sheet of MDF and this is supported on a waist-high bench (my assembly table) that is equally flat. I have run my Starrett flat edge across it quite obsessively. (Sometimes I wake in the middle of the night, and check it some more). Because of the height of the table, I can press down on the plane, rather than push it. I try my absolute best not to do anything that might lead to a curvy sole. What you must NOT do is try and push the plane in the same way you would use in to produce shavings. If you do this you will cause it to move in an arc, and this will lead to the sole being likewise shaped. When you push on the plane (which has, as you know, frog attached and blade inserted but retracted), hold it as much near the centre as possible. Do not hold it by the totes as this may unwittingly encourage you to push it like a plane.
I'm either good at this or lucky. Probably lucky. I've done quite a few planes this way and I've been lucky with them as well.
Bugbear's article on scraping
Re: file - not scrape
paul womack
>Just to say - I tried scraping, and it's slow and tedious.
As you move through the detail of my site, I take the "printing" concept from scraping, but use files (or small, hard convex sand blocks with AlZi) to remove areas revealed as in error. This can remove metal quite quickly, and is independant of the size of the plane.
BugBear
Depends....
>These things fit well under a pair of Levis now I can have nice long shop sessions...;^)
OK all kidding around a side.
First off this is a dry process for me. If you feel you need to use a lubricants use oil or kerosene.
I generally start out with an 80 grit belt, in bad situations 60 grit. Then I work up to 220-320 grit. It doesn�t need to be polished; it�s going to get scratched up anyway. I use 4to 6� wide belts, length depends on the plane its self.
