Anant A52 Plough Plane (Long)
Ron Smith
>There has been some talk here about Plough Planes, and of course it caused me to worry about making proper grooves. The worry turned into a kind of fever so I phoned Highland Hardware in Atlanta to see if they could get the Anant #52. I have bought several Anant planes from Highland, but their Catelog does not show this plane. As it happened they DO stock the A-52, so I orderd one.
The plane arrived a few days ago: Eight inches long, Nine cutters (1/8-5/8 inches) Fully chromed with a pretty spiffy plastic imitation Plantation Grown Softwood Tote. They chromed right over some pretty rough casting, but the fit is excellent, drillings square and threading sound. I assembled and checked for true and square and everything is really quite excellent. Installed a wood fences, sharpened and mounted a 1/2 inch cutter and went right to work on some soft pine. Disaster struck ! . . .These suckers are HARD to use. The plane-bed, skate, or whatever, is a scant 1/16 inch in width . .it has to be that way to ride behind, and support the narowest (1/8 inch) cutter. The plane must be kept almost perfectly vertical or it will not cut, or will cut too deeply. I would inadvertantly tip the plane to the left, it would, or course, dig in and I would adjust the iron for a shallower cut. And it would quit cutting altogether. Took me some time and a whole 2X4 stud to figure out what had me.
My technique has improved some, and by using a VERY light cuts, chopping in from the 'far' end of the piece, and worrying mainly about keeping the plane dead vertical, and holding the fence really tight, I am finally cutting rather shallow, poorly defined groves. I like the plane and feel it is well worth the $116.00 it cost. I imagine the rather nicely machined cutters are worth $50.00 or so. Comes with two sets of fence rods, and a large Slitting Blade for cutting thin wood or leather.
If you have patience, and tolerate defeat well, this might be a good plane for you. But I warn you a single-skate Plough is a challenge. A Stanly 46, with a second adjustable skate, is easy to run by comparison.
