stair project finally done
bill tindall
>Must admit, not much of this project was hand tools. Nothing square where it went, of course, so there was plenty of hand fitting. Thought it would take a day to install, after I got the parts all made and finished. Took a week. Wood is ash, with walnut cap.
Re: stair project finally done
Nice!
>Speaking as someone still recovering from a stair project (porch, not as fancy as your work, but still stairs), I can testify that you should be right proud now.
Ditto!
>Did you turn the spindle work your self?
Nice job Bill...
Scott Burr in Ben Lomond,CA
>Nothing is square...Ahhh yes...I know this well.
Steve Kubien
At least...
Steve Kubien
>...you got all of the spindles right side up. I've seen jobs where the odd one was end-over-end from the rest.
Nice job Bill. I like the species/colour pattern.
Steve Kubien
Wiley Horne
>Beautiful job, Bill. Everything neat as a pin. I'm trying to visualize how you install the rails and spindles, once they're made and finished. Do you assemble the upper and lower rails and spindles, and mount them as a unit? Or do you set the lower rail, and then build up from there?
You've made it look easy, but I can't imagine it is.
Wiley
assembly described on power tool side post
bill tindall
