Handcut dovetails revisitied....
Ken Rozema - Whitby Ontario
>Ok....
I have been practising my handcut DT's and they are actually starting to look pretty good. I think the thing that is causing me trouble (other than a complete lack of skill and sometimes patience) is, how do I mark the tails? I get real nice pins cut and it looks really clean and accurate, but when I mark the tails I can only mark one side of the board. Unlike when cutting the pins, I have no line to follow on the other side of the board. Is there a trick to this? Do I just not mark it, or should I use the gauge I used to mark the pins, etc....? Also, do you use a pencil, or a knife to mark it?
The layout tips worked really well, thanks again for that...it's so easy now.
I will get through this.......any help is appreciated.
Thanks
KenR
Re: Handcut dovetails revisitied....
Ed Snow
>You do not need them on both sides of the board. By connecting the lines layed out by the pins with the saw, you will saw to the right spot on the back. Keep practicing, it is the only way to get it figured out.
Joel
>real simple - I am assuming you now have the angled line of the tails marked on one side of the board. use a square to scribe a stright line over the edge of the board and then use a bevel to mark the other side. The key however is that the angle of all the tails may not be exactly consistent so what you have to do is set the bevel to the actual angle of each tail on the front face and then carry the setting back to the rear face. Of course lock the bevel, and check to make sure it didn't move after you lock it. There is always the potential of having to reset the bevel for every side of every tail but in practice unless you are massivly unlucky modt of the tails will be consistent and you can mark those all at once and then just have to custom set a few.
With practice and as you get more consistent you will find yourself using the rear lines to check yourself less and less and thats when you start thinking you can skip scribing the back. I'm not there yet.
paul womack
>If you don't have a video or book describing the entire process, try these links...
They differ in details, but if you read/browse/skim all of them, you can see which techniques appeal to you.
Alan fousts DT link page
BugBear
Handcut dovetails jig *LINK*
Derek Cohen
>Ken
In addition to the advice given, you may find this jig of mine useful once you have marked the lines of the tails with a dovetail marker.
The jig will enable you to chisel to the line accurately on one side, then flip the board to chisel from the other side.
See the Link for more detailed information.
Handcut Dovetail Jig Mk II
Steve Kubien
Hey Derek
Steve Kubien
>What is the adjustable front board/fence for? Cool jig BTW.
Thanks,
Steve Kubien
Ajax, Ontario
Alan Hamilton
>Ken,
You can always mark and cut the tails first. Half of the adult woodworking population does.
Alan
Kevin French, Antrim NH
>Ken one other thing. Find yourself some #3 EX-hard pencils to make your marks. They don't dull as quick as a #2 and make fat lines and you can see them better then a knife mark. When you can cut a mean DT then go to a knife.
Re: Hey Derek
Derek Cohen
>Hi Steve
The adjustable front piece is a depth stop. It allows you to slide the end up against it, to the depth of the pin/tail. This then permits you to flip the board over and locate the same line on the other side.
Thanks all.
>Thanks for the responses! They are a huge help.
Maybe I'll try cutting the tail first......
I'll post a pic once I manage to cut a nice one.
Thanks
KenR
Steve Kubien
Re: Hey Derek
Steve Kubien
>Well duh! That makes sense. Thanks.
Feelin' kinda dim in Ontario....
Steve Kubien
Dovetail cutting jig
Johanna in Placitas, New Mexico
>Here is one I made (as did most people in my dovetail class). It helps you start the cuts at exactly 90 degrees. Even though I can usually cut pretty straight, I've found that using the jig makes the cutting go much faster.
Re: Dovetail cutting jig - another view
>Sorry these are so blurry - I have a lousy camera! This view shows that there is sandpaper glued to the top and bottom pieces. The rods are much longer than necessary for this workbench, but that is because I also use the jig on a workbench with a deep apron.
