spoon endeavors (disasters?)
mike recchione
>Well, it was a beautiful day here in Northern NJ, and my wife was taking the kids for a play date this aftenoon, so I figured I'd have another shot at the spoon challenge. Last summer I decided that my basement shop, while very cozy and inviting in bad weather, is depressing when it's warm and sunny out. I fixed up a corner of the garage as a nice weather shop, and had just about finished a new, small bench for it, right under the window, when it got too cold to work out there.
Today was going to be the maiden voyage of the new bench and the nice weather shop, and it was a great day for it. I gathered up the tools I thought I'd need, (I still don't have the garage shop fully equipped, and I don't think I'll ever leave my good carving tools out there), and got ready to work. Of course there were about 100 trips back downstairs to get things I forgot, but that was OK.
I picked out a piece of rough 4/4 cherry from the scrap pile, and set about spoon making. This piece of wood was very dry, included both heart and sapwood, and had a few checks in it. I split it in half, drew something spoonlike on one side, and rough hollowed it. After that, I cut the outline with a turning saw and started shaping the back. Got about 40 minutes into it and was starting to worry about finishing in time, when...ooops - one of the checks that I thought didn't go very far decided that all this commotion was a good reason to continue it's journey through the bowl of the spoon.
Ah, I said, I never liked that spoon anyway. So I grabbed the other half of the board, drew another spoon and repeated the drill. I was much more careful about a bunch of things this time. I had the bowl hollowed out, the hang-hole drilled and the outline sawed by the time the timer said twenty minutes. Plenty of time, I figured. I kept the front flat while I did all the shaping of the back, and was just about done with it. The time was now 47 minutes in to the spoon. OK - so I probably won't make the deadline, I thought. No big deal - I really like this spoon.
When the timer said 58 minutes, I had the bowl pretty smooth, the back pretty well shaped, and decided to lighten the handle by taking a little more off the front, and rounding it a little more. I laid it down on the bench, used a #4 gouge to make a stop cut to define where the bowl and handle would meet. Hit the gouge with the mallet and CRACK. The spoon broke in exactly the same way and as a result of exactly the same mistake that caused the one I made last week to break.
I thought I had learned my lesson last week, but I guess I got cocky. Maybe next time I'll actually remember that you don't bang on a spot that's not fully supported by the bench. I had kept the front totally flat as I worked the back, but the back wasn't flat - I should have made all my stop cuts before shaping the back. Or made the stop cuts with a knife instead of banging them in with a gouge and mallet. Maybe I'll remember next time. I have become obsessed with the need for a pancake batter spoon, and won't quit until I produce one if it takes me the rest of my life! (BTW - I don't even eat pancakes :-) But I do make them for the kids on Sunday mornings, so I NEED a better batter spoon. I don't know how I've survived this long using a ladle.)
In any case, spending a sunny, 70 degree afternoon making shavings in a breezy garage, perched in front of a window with a nice view of Spring starting to happen is nothing like a wasted day in my book, and I really love my new shop space.
So - when does this challenge end, anyway? Is there a special mention for the most failures? Perseverence? :-)
Re: spoon endeavors (disasters?)
Pam Niedermayer - Austin, TX
>Boy, it would drive me nuts to have two workshops on site devoted to the same job. You're a very brave man who apparently loves running up and down stairs. :) I agree, though, about basements.
Anyhow, on the spoon challenge, get us a photo and you'll be in the drawing. The important thing is participating, so I've put your name in the drawing. More to follow tonight.
Pam
On two shops and thanks
mike recchione
>Pam,
First, thanks for putting my name in the drawing. I'll try to get some pictures off my digital camera in between meetings today if I can.
On the subject of having two shops, it's really not as bad as all that. I've always had my shaving horse and hewing stump in the garage, and always did my sanding and rough dimensioning in the driveway (poor man's dust collector). Making the decision to include bench work in nice weather was made easier by years of compulsive garage saling and flea marketing that resulted in multiples of most of the basic tools. So it will be fairly easy to equip the new shop with the most important essentials. And I'll get duplicates of whatever's missing, with a few exceptions. Getting the new shop set up the way I like will be a fun project this spring/summer in between work, travel, gardening, music, little league and trying to get back in shape after three years of too much time on the road and sitting in meetings. I don't think I'll be able to totally eliminate running up and down the stairs, but it should get easier as I get things set up.
I have to agree with Pam...
Victor Parisian
>I have tools (mostly non woodworking) spread between my office/shop, and the garage, and it drives me nuts.
I envy you for enjoying a nice spring day.
I just spent the weekend traveling from Austin where I was at an engineering show, back to Houston, to El Paso via DFW and back to Houston again thru DFW - I'm ready for some shop time.
victor p
I have had two shops for years
Ernie Miller Topeka
>And don't do much running back and forth any more. I have mostly power tools in the garage shop and hand tools in the basement. but I have some hand tools in the power shop and a drill press in the hand tool shop but once I get a full set of Demming bits for the post drill I can get rid of that. When the weather is nice out side you want to spend every minute passable out side and when it get nasty you want to spend time in the shop. Best of both worlds I say.
