200+ woodworking book reviews
So what can I use this for?
Skip in Falls Church
>Okay, I've got something I'm not sure what to do with. (Too much time wandering through eBay - and too low a price - what can I say?) The rather well worn paper container it is in is labeled Simonds Saw and Steel Co. flat ground die steel, oil hardening. Non-deforming type (shperoidize annealed) Chemical analysis C 0.85 - 0.95 Mn 1.0 - 1.25 Si 0.2 - o.4 Cr 0.4 - 0.6 W 0.4 - 0.6 V 0.1 - 0.2 Hardening range 1450 - 1500 degrees F. It also has heat treating instructions and graph of tempering temperature vs rockwell hardness. It's about 2" x 18" x (If I read my micrometer right) 0.07".
Would this be any good to make scrapers out of? Scratch stock? Or do I have something too exotic to fool with? Any suggestions?
Skip
Re: So what can I use this for?
>It's not all that exotic. It's O1 tool steel. You could easily make scraper blades from it, or cut it in two and make a couple of dovetail saws. At 1/16" (.0625) it's a bit thick for that, however. You could cut it up and make marking knife blades, etc. It's easy enough to harden and anneal in your home shop.
>Well, I guess O1 is the best If I had to end up with some spare steel. I suppose that most steel that people pick up doesn't come with an analysis and instructions. :) It would have been nice if it were thin enough to make a dovetail saw out of - admittedly, that was sort of my hope. But then I figured that I should be able to make scrapers out of it if nothing else. Is it too thin for scratch stock?
Maybe I'll make a few scrapers in different shapes out of it - I already have the usual assortment. A guy can never have enough marking knives either. Well, I'll get some use out of it one way or the other. Thanks Bill.
Skip
