Veritas - Innovation in Tools
Old plane rehab
Old plane rehab
Old plane rehab
>I have recently come into a number of old planes (and a few other tools). I was figuring on the old 0000 steel wool and WD-40 scrub to get the rust off the upper parts and doing the wet/dry sandpaper on glass for the soles. Anything else?
Re: Old plane rehab
Re: Old plane rehab
Richard A. Gillespie, Jr.
>I would suggest that you use the green 3m Scotchgard artificial steel wool instead of the OOOO you spoke of. Two reasons, one I think the green pads last longer and 4-0 is too fine.
Flatten the sole of the plane with the plane fully assembled and with everything tight so that it is flexed into working position when flattened.
If I was working on the planes, I would pull the frogs off and flatten their faces after removing the lever cap screw. This is, in my opinion, only required for the first inch or so from the edge. I would also check the fit between the frog and sole to ensure there isn't a wobble. Wobbles are rare but need to be ground out if they occur.
I'd also make sure that the tote and knobs are tight. Wood shrinks over the years and they may become loose. I feel that totes in particular may be more like to break when they are loose and able to flex. If your screw is bottoming out and prevents you from tightening enough insert washers between the nut and wood.
The cap iron should be checked to ensure that it connects to abuts the iron without any gaps that would trap shavings as they pass by. Grind and bend as necessary.
Then you can go onto sharpening your iron but that's a whole different story.
Hope these suggestions help
Re: Old plane rehab
Re: Old plane rehab
>OK. Works for me. I was also contemplating making one into a smooth plane. (They are all standard planes with standard geometry). What would be a reasonable angle for the blade?
Re: Old plane rehab
Grind to...
Scott Burr in Ben Lomond CA
>25 deg. and hone at 30 deg. You should get a good lasting edge that way. Good luck getting them cleaned up.
Re: Old plane rehab
SOS pads followed by wax
>I use your basic SOS/Brillo pad in hot water, just like you'd use for cleaning a cast iron frying pan, on the disassembled parts. Then I dry thoroughly with a paper towel or five and apply paste wax, buffing dry.
It's about one SOS pad per plane, and, no, I don't do it in the kitchen sink, because I have a moderately strong survival instinct. I used to use the laundry tub, but would probably fill a pan with water and do it in the backyard since that went away.
