ADVERTISE HERE - FREE TRIAL
L.Hanson
L.Hanson
Jack Guzman from Maine
L.Hanson
>Hello Leif,
I'm getting started making my first plane.I found a style I like(Razee smoother)and a piece of wood(hard maple).I flattened one side and cut out my blank.Then I decided to do a little research to see if I could get any tips that might help with the process.
Looking over some threads here I followed a link to your website and found everything.It's all there. You already did it all,wrote it down and was kind enough to share it all.
So,this is just to thank you for your trouble.I really like the razee style you made but I think I'm going to try mortising a one piece version.Kind of like the sandusky ones.---Jack
Re: L.Hanson
Thanks, Jack!
L. Hanson
>Thanks, Jack!
Glad it's of some help. It's been a lot of fun for me putting it together. Actually, a razee style coffin smoother was what I originally set out to build for that project, but got a bit sidetracked...
Leif
www.norsewoodsmith.com
Re: L.Hanson
sawing the wedge clearance
>Leif,in your tutorial on building a coffin smoother,you were having a little difficulty sawing the sides of the mouth for the wedge and iron to fit.I took the blade out of my bowsaw and threaded it through the mouth opening and reattached it. Cutting the four kerfs was easy and quick.I have a 1/4"fine tooth bandsaw blade in my bowsaw for sawing curves.Any narrow blade should work.---Jack
Re: L.Hanson
Re: sawing the wedge clearance
L. Hanson
>Thanks, Jack - that's specifically one of the reasons I went ahead and made myself a keyhole saw:
Works great! So would the bowsaw blade... I've never made one of those, maybe I should sometime. Hmmm...
Leif
Re: L.Hanson
>Bowsaws are fun.Also,if you use bandsaw blades you have a pretty wide variety of tooth patterns to choose from.They're also cheap.---Jack
