Miter Shooting Clamp question
Guy A - In Ohio
>I know that I just lurk in the backround, but I'm hoping you kind folks can answer a couple of questions.
I want to make a miter shooting clamp . . . Does anyone know of links or plans that I could research online - I'm trying but not having much luck.
Also I assume for the clamp I should use 1 to 1 1/2" dia. wood screw which I will use a tap and die for. But I have heard about using a hand saw and chisle to cut the threads . . . I would really like to have suggestions so I can learn this for larger diameter wood screws (2 to 2 1/2).
Any info or suggestions?
I will be forever in your debt . . .
Thanks
Guy A
Re: Miter Shooting Clamp question
Re: Miter Shooting Clamp question *LINK*
Wendell @ Murphy, TX
>I assume what you're looking for is a miter jack. The link below has the best plans I've found.
I hope some else can point you to some good wooden screw making resources, because I am interested too.
Wendell
ALF's miter jack article reprint
Guy A - In Ohio
>Thanks Wendell
These plans are exactly what I was after!!
Guy
just added this site to favorites...
Victor Parisian
Re: Miter Shooting ......
Dale Lenz-Tahlequah, OK
>Here a pic of another one. This picture was sent to me from a WC person, sorry I have lost his name. Maybe he will chime in.......Dale
I must be really thick headed
Doug Littlejohn
>because I can't figure out from the drawing how it works !! What keeps the plane from planing the jig/clamp, whatever it's proper name is.
Can someone point out a site or other work that walks a person (read especially dense) through just how the fixture works in actual use??
Thanks,
Sherwood
Re: I must be really thick headed
paul womack
Your care. It's the same technique you use when planing a dowel down flush.
BugBear
Alice Frampton, UK
>And often pieces of thin card glued to the faces are used too.
Cheers, Alf
