Easiest plane repair ever
Jeremy Osner
>So I was planing some 3/4" poplar down to 1/2" thickness last night, for the panel of a cabinet door, using for the first time a recently acquired wooden scrub plane. I was thinking, the plane cuts nicely but it keeps getting clogged up with chips and it's a nuisance to have to unclog it every few minutes of cutting. -- I had a similar problem with a wooden jack plane a while back and it turned out to be due to the wedge having worn down so chips would get lodged in between the wedge and the blade. I never did figure out how to repair that and don't use the jack plane in question much anymore, which is too bad since it's a nice plane.
So I was getting annoyed and thinking I wouldn't buy an old wooden plane again if they all have this problem with the wedge... Finally I took the wedge out to examine it a bit more closely and see if I could figure it out, and the light dawned -- the previous owner left the wedge in backwards, and the wood chips were going right in to the gap on the top of the wedge. I flipped it around and the plane works like a charm now.
Re: Easiest plane repair ever
Ernie Miller Topeka
>Let me get thei right you bought an old plane. didn't take it apart and sharpen it. went straight to work using it? Didn't fettel the plane and put the wedge back wrong your self? Sounds like you have been listening to Todd Don't mess with it if it isn't broke. try it out first to see if it needs adjusting and were the adjustments worth you time? Todd Hughs is going to give you an ATTA BOY!
Jeremy Osner
>Yeah it's funny -- this plane I just bought at a flea market a couple months back cause it looked pretty and was cheap, and put it on my shelf of tools... then last night I wanted something to scrub wih and it was the first thing that caught my eye so I just tried it out.
