Plane Maintenance
Plane Maintenance
Plane Maintenance
MarkSmith
>I've got a couple of questions.
1. After taking them apart and cleaning them, I've been putting a bit of wheel bearing gease on the various threads, i.e. knob, totes, frog adjustors, etc. comments? good, bad, necessary, unnecessary?
2. What should one use on the sliding surface of Bedrock frogs? I've been using paste wax, seems to work ok.
Thanks,
Mark
Re: Plane Maintenance
Jim in Burlington Ont.
Jim in Burlington Ontario
>I wouldn't put grease on any of my planes. Next thing you know it's creeped onto a finger then somehow made it's way onto your work and show's up after you put a coat of finish on. I use paste wax and spray product called top coat for threads and hard to reach area's.
>I'm with Jim - I use wax on any screw that will be used a lot. I don't on the screws that hold on the tote (rear handle) or knob or the screw that holds down the lever cap - you want these not to get loose easily.
I do, by the way, wax practically every other surface, whether clean steel or japanned. It discourages rust and helps things move smoothly - and a freshly waxed plane sole just glides over the wood. I use regular furniture paste wax from Home Despot or wherever it's cheap. One $4 can lasts a long time.
Kevin French, Antrim NH
>Some kind of wax OR a bit of Graphite.
Another problem with grease is that it will attract all the dirt. saw dust... etc
Ron Smith
>I use a dab of automotive anti-sieze lube (stuff sold for sparkplugs) on all screws that anchor in cast iron. Seems sensible to minimize wear on these critical threads. It also makes it easier to disassemble, and dirt accumulation under the tote, knob, etc is not a problem.
MarkSmith
>Ron,
My experience has been parallel to yours. I haven't had any problem with grease escaping from the various threads (I just coat them, I don't glob it on). That's why I used paste wax on the bedrock sliding surfaces, because there grease would be a problem. My main thought was
1. Prevent corrosion
2. Make sure I could loosen the threads 20 years from now.
3. I've always (thanks to brainwasing from the male parental unit) considered wheel bearing grease to be very long lasting but inexpensive.
Thanks,
Mark
I use wax...
Scott Burr in Ben Lomond CA
>And that's it. I wax everything when apart after cleaning. I'd stay away from grease because of what the others have said.
