ADVERTISE HERE - FREE TRIAL
Has anyone finished elm?
Erik Godwin in NC
>Folks,
I am constructing an elm desk box for someone who fell in love with the stately giants prior to the blight. Ironically, he has moved to the land of the Dutch...
The lid panels have the iridescent, houndstooth grain that sometimes shows prominently in the lumber. I am looking for a finish that won't obscure that effect. Has anyone done this? My backup plan is oil and then ultrablonde shellac, but I would gladly defer to the voices of experience. Suggestions?
Thanks,
Erik
Re: Has anyone finished elm?
Dale Lenz-Tahlequah, OK
>I've made a few thing out of elm, maybe 15 years ago. I use Gillispie tung oil, AKA wiping varnish. I still like the look of the elm..Dale
Sam Simpson
>Hi Y'all,
Erik, in my opinion elm is the wood that offers the greatest improvement in appearance between it's fresh worked state and it's fully mature state. As a fresh worked wood it's colour is uniform and that wonderful grain you talked about is not very well defined. As the wood matures it darkens to a warm chocolate brown which is easily worn off or masked from appearing. So utilitarian objects naturally develop a wonderful variety of colours that are light and honey coloured around areas of handling and dark chocolate coloured in around protected areas.
To gain this look early in the items history it is best to oil the item and leave it exposed to good light and air flow for a few weeks. Following that, use a burnt umber or vandyke brown glaze to approximate the colour variance pattern. Then instead of blond shellac, use garnet or button shellac. During the application of the shellac, you will be able to further manipulate the colour variations by rubbing more or less in an area, and deliver a very convincing aged patina to the work.
I sure wish there where more of this wood still alive in the world.
Regards Sam Simpson.
I have
bill tindall
>I have made a few things of elm. It is not a very stable wood and I have one cracked panel, but overall ok.
I stained lightly with fruitwood and then some thin coats of water white lacquer so as to not build a very thick finish. It has stayed quite pretty with lots of pink highlights, etc. I would bet that shellac would make a nice finish also. I am not fond of oil on anything but canoe paddles.
