Re: Ohio 05 Plane opinions please.
Neal White
>Many of my users are Ohio Tool. I really like the blades. They are actually two different metals welded together, hard on the top (cutting side) with the rest being soft. The idea is the blade will not vibrate (chatter) as much, and the thicker section near the cutting edge helps as well. The price sounds like it is in line with run-of-the-mill Ohios on ebay, but you can check it out in person, and there won't be any shipping! The problems you mentioned either don't matter, or can be easily corrected.
Ohio Tools tended to be somewhat variable on quality, so look at it carefully to make sure things like the lateral adjuster will work as designed. I have a little # 02 that the adjuster was rivited so far off center the blade will only go from center to the right, so if I ever try to use it, I'll have to pay close attention and sharpen the blade either straight across or slightly canted to the right.
This Ohio does not have a frog adjuster screw, does it? If so, it is much more valuable and collectable - you should buy it immediately, then ping me off-line and I'll give you my shipping address!!! Just kidding.
All that being said, if this is your first plane, and it sounds like it is, you might be better off looking for a much more common Stanley. Parts are more available, the price should be about the same, and properly tuned will perform very well. With an after-market blade, a Stanley can be made to really sing (altho for a Jack plane, that isn't a big deal)
HTH Neal
