What is this?
Rich Glisson
>Someone gave me this plane years ago, and I recently stumbled upon it and cleaned it up. It is missing the iron and wedge and it has a 75 degree bed angle. I Googled intensively but was unable to come up with much info. It is stamped "SCHUTZ MARKE OTT", which I believe indicates that it was made by Ulmia. It is 220mm (8 5/8")long and takes a 48mm iron (end is stamped "48 m/m"). It also has a metal strike button on the end. The Ulmia web site does not list the plane, but Dieter Schmid's site shows a "Toothed plane made by ECE" that is identical except that it has slots for the wedge instead of a metal cross-pin. I researched toothed irons and it seems they are primarily for veneer work. So...I have many questions: Can anyone put a date on this plane? Is it to be used without a chipbreaker? Does this plane have any utility if I were to buy a regular Hock iron for it? Assuming a 25 degree bevel, I could get either a 75 degree or 100 degree pitch. I don't recall any discussion of German-style planes over here on the slippery side. Is that because Americans hate them or because they are so scarce that few have them? Thanks for any info!
