Toolchest and oilstone question
Jack Guzman from Maine
>I was inspired by Don Weber's toolchest in the new PW when I started this.I needed a box that I could sacrifice into the hazardous area in back of my truck.It's for planes,chisels and related hand tools.It's made with #4 grade white pine that I keep around for shelving.The only exception is the tray bottoms which are 3mm baltic birch ply.There are four loose trays in the bottom for stuff and two on top.The planes are in the bottom on the right.
I wanted to keep a sharpening system in it for touching up cutting edges but waterstones won't work in this situation so I got a norton combo oil stone.Only problem is I've never used one.Besides,oil the stone/sharpen/wipe off is there anything else I should know about care and feeding? Use?
thanks---Jack
Re: Toolchest and oilstone question
another look
>I put brass corners on it to keep the edges from getting destroyed in the back of the truck.How well this holds up is anybody's guess.---Jack
>Did the stone not come with instructions?
The main thing I know is: a light oil works better than, say, motor oil. People all seem to have a different combination and are all convinced theirs is the answer. I wander between ATF and Marvel Mystery oil, but people do motor oil-kerosene mixtures, etc. etc.
Neal (San Jose)
>My Norton combo stone is really coarse on one side, and sorta coarse on the other side. Nice for rough shaping, but too coarse for touching up edges on the job. What I normally carry is a soft Arkansas and a hard Arkansas, and that works well for me. If you want to strop it, you are wearing one to keep you pants up, right? I leave my black Arkansas in the shop, as that seems like overkill when I'm in the middle of a cabinet install or whatever. There was a discussion about a week ago about Washita stones that Joel is now carrying at his store, and there was a suggestion that it could be a good stand-alone job-site stone. I don't know about that, as I don't have one.
I pick up sharpening oil in small (8 oz. or so) containers at whatever local hardware store I happen to be in. I think I'm currently using Buck brand from the Borg. It may be more expensive, but at $5 or so, it isn't going to bankrupt me! They are convenient, and last a long time.
P.S.
Neal (San Jose)
>Really nice looking chest.
Re: P.S.
Wally Lloyd, Iquitos, Peru
>In the U.K. I used chain oil mixed with turpentine for honing chisels e.t.c., I found the chain oil stickiness with the turpentine worked really well.
R.J.Whelan
>Jack ... nice box.
I use straight kerosene - learned it from my grandfather and like so many of his lessons I've never questioned it and never tried anything else.
rj
>Thanks, I'll bet that keeps the stone from getting gummed up.
>Arkansas stones- Yea,that's a whole other subject.I grabbed a small Norton Combo at the local hardware store.Basically,I will be removing nicks and putting on a sharp but crude edge.For finer honing I can do that on weekends in my shop with the water stones.I'll try to find a small Arkansas that I can do a little finer honing with.---Jack
Re: oilstone lube question
George in Lowell, Mich.
>In the tool and die shop where I work we use kerosene as a lube when we polish hardened steel areas in our dies. This is tool shapening in reverse. The point is it keeps the stone from getting clogged. I sometimes use WD-40, if I don't have kerosene handy. A quick spray and start polishing.
Baby Oil
Bryan in Broad Ripple, IN
>I use baby oil with my oil stones. It's thinner than conventional mineral oil, and it has a nice smell to boot. Sometimes I wish it were a bit thinner for my finest stones. For my black Arkansas, I use soapy water that has a good deal of dish detergent added to give it a bit of body. The black Arkansas just doesn't seem to have any tooth with the baby oil...too much lubricity. I hate using petroleum based oil or solvents because of the smell and potential toxicity through contact with the skin.
-Bryan
Re: Baby Oil
>I agree with you on the smell thing. I used to be a mechanic and always had the smell on me but now I can't stand even a trace of it on my skin.That is the main thing that has kept me away from oil stones til now.---Jack
Simon Watson
>For travelling around I just wanted bother with an oilstone. The oil seemed to leak out however well I tried to seal it in. The stones are heavy and of couse they dish over time. Have you tried scary sharp? It's very clean. I'm a big fan of stropping too when I'm out and about. For what it's worth, Simon
Re: Baby Oil
>Baby Oil is mineral oil plus additives like fragrances.
Mineral Oil is a petroleum derivative obtained when gasoline is distilled.
Yep...I know...
>Yep....I know that baby oil is mineral oil. But, it's a thinner grade than typical mineral oil found in a drug store. Go to the drug store, find baby oil, and mineral oil (it's in the laxative section) and compare the two. Baby oil is quite a bit thinner, at least here in the midwest.
-Bryan
I'm no help here but...
Scott Burr in Ben Lomond CA
>That's a nice chest! Great job on it.
Scott who knows next to nutin' about oil stones.
>The problem with scary sharp is the flat surface.Maybe I could keep a marble tile behind the seat in the truck.Nah,that's just too much bother. I guess the main thing I wondered about the oil stone was if just wiping it after sharpening was enough.Do these things need cleaning?---Jack
Re: I'm no help here but...
>Thanks Scott,I'll take a picture of it after a few months or so.I'll bet it don't look so nice then.This is a kind of experiment.Eventually I'm going to build one out of hardwood.I need to figure out how well this one works and what is needed to improve it.I already wish it was a little deeper.---Jack
Mike G.
>It don't matter how big you make a tool box, it still aint big enough.:) You'll just fill it with more tools.
Mike G.
Comparing Baby & Mineral Oil in Store
>If I do that people will look at me funny.
>That sure looks like a handy chest. Being in the back of a pick-up, are you not worried about the chisels banging against each other, and nicking the cutting edges?
>They're pretty beat up to start with.They rest in a separate tray and lay flat so damage should be minimum.Eventually I'd like to have them stored vertically in separate slots but that will be another future chest.This is much better than how I was carrying them before so no,I'm not worried about about a little rattling about.---Jack
Bench Hook
>Jack,
I have not read th eother posts, but to use the oilstone to best advantage I suggest a bench hook, that you can place anywhere flat, a bench of course if possible, but a saw horse or even just a pile of lumber will do, make it so the oilstone sits in a slight cavity, so it cannot wander and you will need rags to clean tools and stone, as the bench hook will become oily, keep it separate, I keep mine in a plastic container and discard rags as I use them.
Back to snow shoveling...
Jorge
Re: Bench Hook
>Thanks for the tip Jorge.
It seems like the snow shoveling is endless this year.---Jack
