Odd flea market find
Dennis
>Picked this up at local flea but not sure what it is for. Not too often i see something like this and the buck bros stamp. Maybe for chair making but really not sure.
Dennis,who is enjoying some rain in south florida
remove nospam for email
Re: Odd flea market find
Steve Kubien
What you've got there is...
Steve Kubien
>a bonafide thingamabob! It's for cutting a tapered hole, as per making chairs. I didn't know Buck made drilling tools, but then again, there are MANY people with more historical knowledge than I.
Steve Kubien
A reamer with a broken tip?
Pam Niedermayer - Austin, TX
Ernie Miller Topeka
>It's a toad sticker and toad season is opening up in a couple weeks here so send it to me. Nice find.
Michael R
>I could be wrong, but I think it's a bit for making tapered holes with a hand brace. Probably works best with a pre-drilled hole.
Traditional chairbuilders, among others, often use tapered holes.
Michael R
Reamer for screw
David Miller from Iowa
>When working in hardwood, they used to predrill the hole, then use this reamer to shape the upper part of the hole where the screw body was, then they would countersink it. Hold up an OLD screw to this and you will see it is the same taper.
Todd Hughes
>Tapered reamer as others have said. I think these solid ones are more for metal working then wood. Ones for Wood are "hollow"[ dished out] and have two sharp edges. I don't see how one like this would cut wood though I could be wrong...A pretty common tool though the Buck stamp adds interest to it.....Todd
A question for Todd
Adam Cherubini
>Todd,
Were reamers like this one used to "ream-up" a hot punched or cast hole to a finished size? The taper is shallow and the diameter is too large for wood screws, too small for chair parts.
I've used reamers like this to enlarge holes in thin metals to desired diameters. I also reamed my dowelling plate holes, which I think, makes my plate work a lot better. The plate can be "sharpened" with just a few cranks of the brace.
The tool itself can also be sharpened.
Adam
Re: A question for Todd
Greg Betit, Crown Point NY
>The best tapered reamer I have used for chair legs is not the dished type Todd refers to, but the solid metal tapers with a divot cut for scraping action that Fred Emhoff makes. This tool would have that same action.
As far as being too small for chair parts- it depends on which chair part.
The top of a bowed chair typically typically has the spindles passing through the bow and wedged. That keeps the parts separating if you pick the chair up by the bow. If you look at this joint on a chair that has been around for a few years, many of the spindles are proud of the bow. This can be prevented If the bottom of the hole is flared slightly and the top of the spindle tapered to fit. This was shown to me by the best chairmaker I have met, Dave Sawyer. If I had Dennis' tool, that's what I'd be using it for.
Greg B�tit
Not Todd but
Bob Hackett
>A tapered reamer is used in metal for many of the same reasons it`s used in wood.It can provide a "lead in" for a part that fits into a hole or it can form a mechanical lock when the part in to hole is either wedged or peened to fit the taper.
These are just two examples.
If a hole needs to be reamed to a finished size then a reamer of the correct size(usually with a tapered or beveled starting section or pilot) is used or an adjustable reamer can be substituted and the hole reamed alittle at a time till it`s within tolerance.
Tapered reamers are usually reserved for thin material or rough work in metal if the hole was originally meant to have parallel walls.
Mainely,Bob
But...
>Don't you folks find it odd that a metal working tool is fitted with a tang for fitting into a bit brace? That's what leads me to believe it is actually a woodworking tool...
Greg - who has a similar tool, but it is a tapered square cross section instead of a semi-circle.
I agree.
Bob Hackett
>It may be a wood working tool.
You`d be surprised how many uses a brace has for metalworking though.Think of all those twist drills and countersinks you see with a shank that fits into a brace.Not to mention those funk,chain tightened drilling rigs and screwdriver bits.This list goes on and on.
The question from Adam was,would a tapered reamer be used to ream a hole in metal to final fit.That was the question I thought I was answering.
Mainely,Bob
Not Strange
Todd Hughes
>Here is a cut taken fron an original 1914 Blacksmith catalog I have that shows a different type of reamer for pipe and other metal working and as you can see it has a square tapered tang for a brace.Lots of other tools for metal work such as die holders, twist drills, nut wrenches and other counter sinks are shown for metal work but designed to go into a brace. Sometimes we forget but befor electric lots of holes were drilled in metal as well as wood with hand tools such as braces. Think of all the chain drills you see which were mostly used to drill holes in metal like pipe and all had square shanks of course.....Maybe the reamer in question could be used for wood, I'm not sure but I don't think it will work very well, at least not as good as the more tradtional type.....Hey why not give it a spin and tell us how it does? .....Todd
Todd Hughes
>I have used ones sort of like the one in my photo, but at a more gradual taper, in riveting. Useful to make sure the holes line up in thinner stock and in thicker stuff gives you a tapered hole that the rivet or the peice being peined will expand into and still hold if filed flush. Have also used them to make holes slightly larger......One of those things you probaly don't have a need for much but when you need it you need it....Todd
Dennis
>How are these sharpened?
Dennis
Adam Cherubini
>I have sharpened similar bits by honing the flat to make a nice sharp corner. Inevitably, you find more wear in certain areas. If my theory of use is correct, you may see that wear mostly around 1/2", 3/8" or other common diameters. Anyway, in those locations I work the conical part. I have other reamers that are 4-sided and these work well and are easier to sharpen. They are all scraper like, but can pull nice shavings from soft metals.
Adam
Dennis
>Thanks Adam
Very helpfull,spent some time checking wear spots but nothing for sure. Using my fingernail i only found on spot at 7/16 that maybe is a wear spot. All this makes me wonder if one would turn it clockwise till dull then ccw to use the other edge.
Dennis, who had great day rust hunting
Adam Cherubini
>Hey! Yeah that's interesting! I think you can "pull' a hole (change its location) by racheting. I think this may be a legitimate reason for reversible bits.
Adam
Re: sharpening
>Why wouldn't this be an ideal application for scary sharp? Make a very deep hole with the reamer, the depth of the length of the reamer that you want to sharpen, line it with sandpaper, and turn away with a brace. Of course, you'd still need a slip stone or sandpaper on a stick to take off the burr.
Pam
