Work bench use photos & comments *LINK*
Alan Bierbaum
>This posting was expedited by last night's hand tool chat room conversations.
After using my bench, and answering questions from internet viewers on the bench page, I am starting to compile some information for publication on this page. I will update / modify this page based on comments received.
My bench is sized to fit my work area and the expected use of the bench. Without vises, the top is 35" deep and 84" wide. Depth across the face vise (without handle) is 45 1/2" and length across the closed tail vise (without handle) is 89". The tool tray is 7" wide (part of the 35" depth) and 2 1/2" deep. The bench is 35 1/2" high (to match my table saw height). My barefoot palm height is 34 1/2". The longest piece that I can clamp in the tail vise is 84". The face vise front (movable) face is 11 1/4" wide. Dog holes are rectangular and are 2 3/4" from the bench edge.
My bench is used for hand tool and power tool applications. It is also my sanding and assembly table. The depth of 35" allows me to assemble three foot objects (like a desk) without having to use a secondary top for support. This depth also allows me to work parts and still have the final product remain on the bench top (pushed to the side/back). There is room all around the top the allow clamping objects to the top.
Do I like it? YES ! Would I do some things differently? YES. Based on my constraints; the only thing that I would change is to move the dog holes closer to the front edge. This would allow moulding plane use on narrow boards clamped by the tail vise. If I had the room; I would make the bench longer. It would be nice to be able to clamp 8' (or longer) boards with the tail vise. For sawing dovetails (in the face vise) and chopping dovetails (near the tail vise); I would like the bench to be several inches taller (easier on my back). Using hand planes would be easier if the bench was 2-3" lower. For my work; I would not change the basic design. The only change that I made from the original is to add three drawers above the lower support stretches. The original shelf collected junk and the drawers hide the junk. The drawers also act as supports for long stock clamped in the face vise for edge jointing. This saves me from making a sliding board jack or building a separate support for long boards. The finish is several coats of WaterLox followed by several coats of paste wax. I rewax about every six months. I cleans up nicely. The top is still within a few thousands of flat and has not been resurfaced (a heated and air conditioned shop probably helped).
In the following link:
The following pictures are taken from some recent project pictures (they are not staged) and show actual bench usage for me. There are some holes in the usage pictures as I do not have pictures of all of the uses for my bench. There is no real sequence to the pictures.
Web page with pictures - Large pictures
