Marking Walnut
Marking Walnut
Marking Walnut
Matt Malin
>What is the best way to mark the layout for dovetails in Walnut? I don't think a pencil is going to work too well.
Re: Marking Walnut
Fine gel pen
Dan Donaldson
Re: Marking Walnut
Marking knife
Michael R
>Make a marking knife (striking knife) out of scrap metal or buy from Woodcraft or another vendor. You'll get the finest, most accurate line I know of, and the line makes a physical guide for your chisel. It also cuts the surface fibers so you get al little less fuzz when sawing.
Re: Marking Walnut
Re: Marking Walnut
GolfSteve in Calgary
>Here's what I do, assuming you cut the tails first...
Mark the tails with a RED PED. It really works. The red ink is easy to see on the walnut.
Then mark the pins with a marking knife as usual. Use a bit of white chalk to highlight the knifed lines.
Re: Marking Walnut
Re: Marking Walnut
Paul in NJ
>Use a marking (striking) knife and rub a little chalk in.
Paul Dzioba
Re: Marking Walnut
What Michael said!
Alan Hamilton
Re: Marking Walnut
The Official WC Sir William Endorsed Marking Pen
>... is a Pilot P500.
Re: Marking Walnut
Re: The Official WC Sir William Endorsed Marking P
>Credit should go to Bill Tyndall, who did the basic research and announced his findings here first.
A couple of warnings: The Pilot is not suitable for rough sawn lumber, which will often break the tip off. It is also not suitable for softwoods, which will just gum up the ball. I did those bits of research myself.
Re: Marking Walnut
Re: Marking Walnut
Clay C in Miami
>Having done lots of walnut-marking lately, I'd agree that a knife (with the line 'filled' with chalk or a yellow artist's pencil) is probably best. I've also had some success sticking some of the light-green tape on the surface, and then just marking on the tape.
Clay
