Tuning a Stanley #140 Skew Block Plane (part 1)
>I use a vintage Stanley #140 skew block plane to tune tenon faces (see Picture 1). For those unfamiliar with it, it has a skewed blade and a removable side The modern version of this is made by LN, which is different in a few important areas, such as a lower bed angle (the Stanley is 20 degrees while the LN is 12 degrees), and a much tighter mouth (the Stanley, by comparison, positively gapes). One could also mention the better construction of the LN (bronze) against the Stanley (cast iron), as well as the better blade (1/8� A2 steel) verses the 1/16�. Not only that, Garrett Hack remarked in The Handplane Book that �this should be an incredible tool, but mine has always fallen well short of expectations � it cuts poorly�.
After all these negative factors one would have to question just who wants a Stanley #140 anyway! Well I did some time ago, and I know that these are many others who own and use one as well. And probably with the same mixed feelings I have had. But no more � we Stanley #140-ers are going to rise up and take our places on the podium. With a few tweaks, this can become a mean fighting machine!
I began tuning the #140 about a year ago. This involved:
(1) Levelling and raising the frog � unless the frog is level, the blade will end up cantered to one side. The usual method of fixing this is to carefully file the high spots on the frog. Here, however, this will not work since, if you do this, it will lower the frog, effectively raise the bed angle, and widen the mouth even more. What we want to do instead is to raise this area, since then the blade will close the mouth nice and tightly. You can test this out by adding a little packing under the blade at the mouth. To do this I used a little 5-minute epoxy. Place this on the frog (see Picture 2) and then seat the blade directly over this (making sure that you cover the contact areas with a little oil as a release agent first). Press down carefully, and adjust from both sides until the blade is perfectly aligned with the mouth. This will close the mouth up as tightly as you desire.
(2) The original Stanley blade was replaced by a LN Stanley Replacement blade, which was thicker and better steel. Actually, the main reason for replacing it was that the original blade was out of skew and I just could not fathom how to get the mouth-blade area right. The LN blade arrived and turned out to be slightly out-of-alignment as well! I have been living with this until now. It worked OK, not great, certainly not as well as I expected it to do so.
(End of Part 1)
