Freezing shafts and baking bearings
>Got to put a bearing back on the shaft of an electric motor. this bearing would normally be pressed on, but alas, I don't have a press, sooooooooooooooooo, I've put the shaft in the freezer, and intend to put the bearing in the oven tomorrow. Thought that arond 100 degress for 10 minutes or so should do the trick eh? Unless of coarse you all think that with the shaft frozen and the bearing at room temperture should be suffecient. Any thoughts/experiances/suggestions/past disasters/sucesses on the subject?
Todd O.
Todd O.
