Planing without a blade
>I was interested to find how long it took to hone the Smoothcut blade on my Stanley #7 with a 6000 waterstone (only) following a grind on 600 sandpaper.
I duly did this - it took about 20 strokes - returned the blade to the plane, and set about planing some Jarrah.
The plane felt hard to push but it was producing extremely thin, lacy, full-length shavings. However the surface of the timber felt rougher than expected and there was not even the hint of shine. I swapped to my HNT Gordon Try Plane. This produced even thinner shavings, and more importantly left a glowing surface on the Jarrah.
This can't be right, I thought. Obviously the blade has a rough leading edge, a result of poor sharpening. So I removed the blade from the #7 to examine it more closely - to find that the chipbreaker had slipped down over the front of the blade, and all my shavings had been produced by the chipbreaker itself!
So who needs a blade - just sharpen up the chipbreaker!!! :)
Re: Planing without a blade
Dang! I'm Still Trying to Learn
Bob Hutchins in Central Texas
>how to sharpen the iron and NOW you tell me I've gotta learn how to sharpen the chip breaker, too.
Chipbreaker planes jarrah, eh?
BobH
Lyn J. Mangiameli
>No let's see, was that a convex, high angle, bevel up chipbreaker? :-)
>Let's look at your configuration a different way. What you are saying is that you put the thin, flexible blade on top, raised both the effective cutting angle and the relief angle, and put the thin, flexible blade stiffener underneath, extending the support for the cutter well beyond the end of the frog, which was always a serious problem with the Bailey design. And, you didn't need to increase the thickness of your cutter to gain these advantages. Fascinating. You'd probably be wise to make sure you aren't violating any recent plane patents with any of these innovations, before you try to sell any of these.
Greg Sloop, Portland OR
>A screwdriver, bevel up and down simultaneously, held down with a Taiwanese pair of "vice-grips" does almost as well in my triple blind, placebo controlled studies. (The guy pushing the plane and judging the samples is actually blind.)
Cheers,
Greg
Re: informative
paul womack
>Actually, pushing a plane without a blade can be remarkably informative about how much of your effort is going into frction between the sole and the workpiece, and how much into cutting.
A non lubricated #5 generates a horrible amount of drag.
Try it.
BugBear
Re: informative
david charlesworth
>Paul,
That is why the metal polish & wire wool is so useful as the last stage of 'plane sole lapping'. It reduces the frictional drag significantly.
I finish lapping larger planes on blunt 240 grit wet & dry or maybe 320, and then scrub hard with Autosol/Peek/MAAS, chrome polish and 0000 wire wool.
Also as I use Camellia oil as a routine when putting tools to bed, there is a small trace left even after the excess has been removed with the "oil removing cloth" which sits on my bench.
0000 ww & metal polish is also a wonderful way of removing the first traces of rust or tarnish.
David Charlesworth
Thinking of a new study, Lyn?
What sort of metal polish do you prefer?
Clay C in Miami
>I didn't think he flipped the iron/breaker over, just that the breaker had slipped down past the edge of the iron ...
Clay
Re: ?
>Yes, of course, I was just adding a little more twisted humor. The blade was not performing any cutting action in that configuration, but it still was an important part of the system, and contributed to the results he reported, if only to support and dampen the vibrations of the finely honed and tuned cap iron. If you don't think so, you might try another experiment: remove the cutter entrirely and attempt to plane using the cap iron alone.
density
Clay C in Miami
>Sorry to not recognize the humor, Sir W - sometimes I miss it in cold print ... and, much of the time I can just be so incredibly dense that light will bend around me.
Clay
Re: What sort of metal polish do you prefer?
david charlesworth
>Don,
I use Autosol which is sold in car acessory shops here, (in a tube).
However any brand will probably do.
Tormek leather wheel honing past is also fine.
best wishes
David Charlesworth
paul womack
>David said:
...then scrub hard with Autosol/Peek/MAAS, chrome polish...
Googling gives...
http://www.totalmotorcycle.com/reviews/AutosolReview.htm
http://www.caswellplating.com/aids/peek.html
http://www.maasinc.com/faq.html
Since chrome is so hard, the polishes for it are the most aggressive, and hence useful for performing substantial work. I wouldn't use them on the family silver ;-)
I second David's tip of chrome polish on 0000 wire wool for removing rust.
BugBear
>Hi Bug,
I think we had this conversation a few years ago. Those brands are not available here, but there are USA domestic equivalents to be found at auto parts stores, I believe. There is/was a tube-dispensed German chrome polish that I used to use on my 'cycles years ago, the name of which escapes me.
Thanks,
Don
paul womack
Indeed. There should be sufficient information in the links I found to either source the same product, or accurately identify an equivalent.
And, hey, you Stateside guys need to bear this brand-name thing in mind next you casually talk of brushing on a coat of Watco...
BugBear
Simichrome.
Bob Hackett
John Meikrantz
>Maas is available here in the US. They sell it by the tube at Walgreen's (drugstore chain). There are a number of polishes/cleaners that I see in the auto parts stores, and I'm tempted to give them a try sometime, i.e. Mother's, Blue Magic, Nev'rDull, etc. If only there was some way to differentiate, based on formulation, etc. It is all closely held information, though.
John
That's it.
