Plane iron testing plan (Was: Infill plane) *LINK*
Brent
>In a long thread on *infills* Joel (joel) suggested a type of plane iron test that at first seemed unnecessary. He said:
"Most formal tests of planes are done only with pristinely sharp irons which evens out the performance between planes."
My tests actually test blades to the point at which they no longer cut. I run 'em till they drop. In fact, what I am looking for is durability, which I can measure, rather than operation when sharp, which I cannot. He then said:
"I don't actually know of a test that took similar irons in different planes and used them to see how long the plane could go between sharpenings."
At first, this made no sense to me. Why would using a different plane affect blade durability?
There is however a possibility that this is a source of variation after all. My theory of *dull* is that a blade feels dull when the *wear bevel* on the downward facing edge is wide enough that we can no longer press the blade into the wood with reasonable pressure. On many blades the edge is still sharp - if we raised the bedding angle 10 degrees we could start all over again thinking the blade was sharp without sharpening it. It would be a larger included angle, but the edge itself is still in good condition.
So, why does the plane matter? Well, the abrasive action of the wood rubbing on the blade increases with the heat generated, which in turn increases with the pressure applied. So, the plane that lets you cut with the least possible pressure is the one that gives the best durability result for a given blade.
The problem is, what selection of planes are there for a given blade? Joel appears to have a selection of Norris planes to use. That would not be useful to most people -- a few on this list, but not most. It is certainly not something I have around to use in a test.
What selection of planes would make a reasonable test? That is, a test which people could repeat to verify the results. As well, a test which would help people select between planes they could actually buy.
If people can come up with a selection of readily available planes all of which take the same iron, I would be interested in doing the test.
My plane tests are at the link below. I am currently testing some irons from Japan Woodworker and will be including those results in the next week or two.
Brent
Plane iron tests
