Jennings or Irwin
Jennings or Irwin
Jennings or Irwin
glh
>I'm thinking about buying a set of auger bits for a hand brace. I plan to use the bits mostly on cherry, walnut, maple, oak, or poplar. Which style bit is better for these hardwoods, or does it matter?
I think I read somewhere that the Jennings pattern was better for hardwood, but I might be wrong. I want to make sure because I can buy a set of Irwin bits quite a bit cheaper.
Re: Jennings or Irwin
Paul in NJ
>What you want to look for are auger bits with a fine pitch lead screw. The coarser pitch lead screws are for soft woods.
Paul Dzioba
Auger bit file
Jim Reed @Tallahassee
>It would probably be worthwhile looking for an auger bit file. They are small wierd shaped files with teeth on parallel faces only. This lets you sharpen one leg of a corner without bothering the other. I find my augers work better when they are touched up a bit.
Adam Cherubini, NJ
>I vote Jennings. They have a hollow center which eases chips. Get the fine lead like said (Hi Paul!).
Adam
glh
>Thanks, I'll go with the Jennings fine thread. Thanks also for the advice about the file.
Ron Smith
>Proper bit election involves a bit more than one might assume. I bought a set of Irwin bits with little knowledge of the intricacies involved. And, or course was disappointed to find that the resulting hole size is wrong for my application. One might reasonably assume the No. 8 (8 1/16th) would drill a 1/2 inch hole. Well, that is not always true. The Irwin Booklet that came with the bits says, on page 5 . . "All auger bits, except those made especially for doweling, are ground approximately 1/64th oversize . . " I found this to be true, and the bits I bought are virtually useless for fitting dowels. Also the Screw Point Pitch is critical . . the seem to offer three pitches . .Fast, Medium, and Fine Screw. The 'Fast' is probably OK for soft-woods . . but drilling harder woods will probably require use of a finer thread . .Medium, or perhaps Fine. This, according to the irwin Handbook, Page 6.
Then there is, according to the Irwin Handbook, the 3-Head. 4-Head, 5Head, 6-Head and No. 61T Dowel Bit . . . . .making selection a somewhat deep study. I wish you good luck in your selection.
Fred Peake
>They developed their bit sizing based upon their customers needs. Most users didn't want a bit that drilled a 1/2" hole, they wanted a bit that drilled a hole for a 1/2" bolt for a gate, bench, or whatever. The extra 1/64" made for a much smoother assembly. There are exact size dowelling bits out there, be on the lookout for them. They are about half the length of regular auger bits. I was fortunate enough to get a lot of about a dozen on e-bay a while back. There were even a couple that were numbered in 32nds, one marked 11 was 11/32". I would sure like to find the rest of that set, but they probably were never sold as a sets, just odd sizes purchased at need. Another option for exact sizes is forstner bits. They are pretty rare, but do show up occasionally.
Jennings for hardwood...
Scott Burr in Ben Lomond CA
>Irwins are for softer gummy woods (pine Doug fir). Think quick dirty holes for construction work. They have large pitched lead screws that have a tendince to strip out and not grab in hardwoods.
As said, it has to with the lead screw pitch. The bit pattern its self, as Adam states has more to do with chip removal and how clean of a hole it produces.
A good starting set for hardwoods are the Jennings No. 100 IMHO.
I prefer the No. 101's (these have a finer lead screw than the 100's) but they are hard to find.
Nemo Tools
>This discussion has been helpful for me. I wish there was more information about bits. I have a slew of bits I've picked up cheap at various garage sales, but I don't know squat about them.
Re: Jennings for hardwood...
glh
>I check into the numbers. The bits I'm looking at are at www.toolsforworkingwood.com under the "Drill Equipment" section. The info simply says Jennings pattern, but gives no numbers other than size. I'm going to call and talk to someone there before I order though. Thanks again for the information.
