Sharpening Question #2-Plow Plane Irons
TomH
>I have a wooden plow with a set of irons. What angle is the primary bevel supposed to be? Is a secondary bevel recommended on these irons? Again, thanks.
TomH
I start at
Jim Reed @Tallahassee
>about 30 degrees. You can adjust accordingly. If the steel bends, go higher. If you are planing very soft woods, take it lower. Good luck.
