You can teach an old dog plane old tricks...
steve antonucci in NW NJ
>So I decided to take my old wooden jointer and ruin the antique and collector value of it by making it a serviceable tool again.
I've never understood how something old that didn't work for it's intended purpose could be worth less if you fixed it. To that end, I took the iron out, and ran the sole across my jointer to flatten it.
In doing so, I discovered that it appears to be made of beech. I also glued the crack in the handle. Below is the result.
Thanks for the advice. I guess I'll just have to go out and buy a chandelier for the shop now...
Steve
Re: You can teach an old dog plane old tricks...
John Snyder, Pocono's PA
>I never worry about collectible value for common planes - its rewarding to salvage one from despair, eh ?
JS
Todd Hughes
>When you asked about the plane befor I thought it was a wood plane that someone had put a Stanley Sedgly blade in it and not a Sedgly Transitional plane....Don't worry about hurting the vaule with the cracked handle it was probably wort $10-20 and it is still worth $10-$20......Todd
Please tell me more...
>I'm not a collector, but I certainly admire a well tuned plane. From my picture, can you tell me a little bit of the history.
If I recall correctly, I won it with about 12 other tools in a box lot (I think it was what I was bidding on, and I was happily surpised to see it came with a box of carving gouges and calipers- $20.)
Steve
Gloating over a working transitional plane (whatever that is.)
Ernie Miller Topeka
>A transitional is a wood plane that has the improvments of a metal plane. the metal blade adjuster the lateral adjuster and metal parts. Kinda the best of both worlds. hated by many loved by a few who take the time to tune up and make work. That one is a rather nice looking one. you should see the Keen Kutter I bought the other day. broken blade, busted tote and it looks like either a bever or pack rat chewed on the heal. what a sight to see. just junk in the bottom of a box.
Thanks for the info
>Aside from the mouth being a little too wide, I bet this plane would do an excellent job on most woods. I set it to cut the shavings you see (with almost no effort) and they're cut so thin that they are "magnetic" - static clng if you go near them.
S
Re: Thanks for the info
Ernie Miller Topeka
>You can allways patch the mouth to close it up if you need to. Them big wood planes take so much less effort to push.
Glad to hear it turned out...
Scott Burr in Ben Lomond CA
>Good. Looks like a nice user plane ya got there.
