Re Japanese woodwork
Andrew Pallas
>Thanks for the responses to my earlier post.
I'm in the process of building a pair of trestles for a beam and trestle "bench", as used by Imai and Swenson and illustrated in The Workbench Book by Landis. Does anyone have any tips/insights on using this type of set-up, to help speed my learning process (and reduce frustration/bad language/skinned knuckles etc.)?
I figure this is the simplest "bench" to start with, I can imagine getting on with it, and if not I won't have spent a lot of time or money finding out what I really want instead.
May your cuts be straight and your shavings thin. (a brand new old Scottish saying!)
Andrew
Re: Re Japanese woodwork
Chuck McKinley
>Hi Andrew,
Where are you? The Society for Contemporary Crafts in Pittsburgh has a class comming up. Their rates are very reasonable. I think it meets one night a week for 4 or 5 weeks.
Chuck
Chuck McKinley
>Hi Andrew,
CM
Manny
>Andrew,
The bench in the pic below was one of the first projects my Japanese woodworking instructor, Jay Van Arsdale, would have us do. It's based on plan that sold with a video he made in the late 80's. Unfortunately it's out of print.
What I and others have done is refine the bench and trestles as we worked with them to better fit our working style. I use mine mainly for mortising and some cutting operations. For example, I just finished using it to cut the dai for the plane in the picture. For mortising I considered the height of the trestles and the width of the beam. That dictated whether my feet touch the floor or dangle in the air. You have to consider what else you plan to use it for. Maybe you want two beams on there so you may need wide trestles. Another consideration is where to put the other tools you need while you're working. Maybe two beams with a thinner plank in the middle to act as a tool tray? One time (and believe me it was the last time!) I had one chisel that was laying on the beam while I was mortising. I wasn't paying attention and it rolled off onto the concrete floor.
The trestles in the pic are "knock-down" Meaning that the mortise and tenons are not wedged, glued or pinned. I can take them apart for storage or, more importantly, to modify as needed to fit my style or the task at hand.
One more thing; For mortising you want a beam that's thick, dense and can act as an anvil. I also place the beam and lumber so I'm hammering right above and inline with a trestle leg.
Hope this helps.
Andrew Pallas
>Thanks for the thought Chuck, it sounds great but I'm a ways off here in Scotland. I'd love to hear feedback about what people learnt on these kind of courses though, maybe I could get a bit of it second hand! Sorry it took me so long to reply, my ISP has been ignoring me . . . must be something I said!
Andrew
Andrew Pallas
>Hi Manny
Just the sort of feedback I need! I am indeed planning a two beam setup, with the main beam around 12 inches wide and the second beam narrower, plus a �one by� whatever I can get as a tool well. I�ve just started on the trestles, and mine will be 33 inches wide, allowing me flexibility in how I arrange these components to cope with a variety of work piece sizes.
Taking advice from the local sawmill owner, I�m planning to laminate the beams like a European bench top. I�ll probably use 4 by 2�s or 4 by 4�s, depending on what looks best when I go shopping for it. He suggested that I�d have problems getting a single piece beam that would stay anything like straight.
I�m hoping to use the bench for most jobs including planning, so I�ll be fitting stops, which I noticed your bench has too. Any other advice/tips you can offer on using such a bench would be deeply appreciated.
Thanks
Andrew
