Rob Lee - Do you carry Pin Pushers
Andrew F in Australia
>Something that I can use to drive panel pins into moulding without using a hammer? - They look like a hex-drive screwdriver but have a spring loaded shaft (with about 25mm/1" of travel) surrounded by a sleeve at the business end of things - tip of the pusher shaft is magnetised to hold the pin in place.
You put the heel of your palm/ball of your thumb onto the back of the handle, locate the sleeve where you eant the nail to go and simply push the nail/panel pin into most timbers.
I know that you are probably aware of what a pin pusher is (telling g'ma how to suck eggs), but included the description for those that aren't familiar with the beastie.
Anyway, do you carry one (as a quick glance of your catalogue proved fruitless?)
They're about the easiest way to deal with panel pins that I know of.
Cheers,
Andrew
(with a potential job involving hanging crown moulding off skyhooks and installing the same, preferably without using a hammer)
