New Machines
New Machines
New Machines
Rob Lee
>Hi �
More new machines being set up now � actually, one is in use already.
The first is a little 24� surface grinder :
Small Grinder
Right now � it�s working on some parts from the past�.
Mystery Part
The large grinder is quite large � a 16� x 12� footprint�. With a 60� by 20� grinding area�
Large Surface Grinder
One of the cool features is an auto-dresser for the wheel�.it can be programmed to dress .002� off the wheel before taking a finish cut�.and auto-compensates for wheel wear.
Wheel Dreeser
Hmmm�.
Now we just need some long stuff to grind�.
Cheers �
Rob
Re: New Machines
I've Got s 37 1/2" Jointer Shell...
Doug Evans
Re: New Machines
Re: what are the chances
>of sending you an old Stanley plane and having it surface ground? And if so, what would it cost? I'm thinking of jointer planes specifically, but it would be nice to have a really flat smoother also.
Re: New Machines
They're pretty now, but....
Dave Anderson Chester,NH
>I want to see picture of the machines after about 6 months of work. I have a love/hate relationship with surface grinders. They do a nice job, but they sure do make a mess, even with flameproof dust collection setups. Nothing like lots of magnetized bits of steel dust hanging off of everything. Oh, yeah, I forgot you have a maintenence staff.
Re: New Machines
How about grinding the ultimate bench...
Eric Hedberg
>on that new grinder. A 20 by 60 precision ground metal bench would be pretty handy, all my builds would be square and I could just throw a piece of sandpaper on it to flatten a blade/plane or true a stone. Hey, you could even cut it for a drop in router! Just imagine the magnet possibilities! Of course then the question is what would be better wearing, high carbon or A2. Eric
Re: New Machines
Re: How about grinding the ultimate bench...
>But, who's going to pay for the shipping? Steel would be nice, since with rare earth magnets maybe we could do away with dogholes, etc., but a 14' Shaker benchtop in granite might be even better. We've ALL been taught to work ON our benches, not IN them, so inadvertant collisions between cutting tools and the bench top is not a significant issue, right? OTOH, isn't periodic reflattening of one's benchtop as much a rite of passage as building it in the first place?
How about a tail vise, shoulder vise, and holddowns, all with computer-controlled stepping motors, all accurate to .001"?
Rob, I'm sure you have many practical uses for this machine, even though they may eventually be appreciated by the end users of your woodworking tools only in terms of price, precision and quality. Longer straight edges, longer jointer planes, and double tapered two-man crosscut saws aren't going to pay for this level of performance. We don't need to build that many conference tables for Forture 500 board rooms:^) OTOH, I can envision you using it to meet our demands for hundreds or thousands of really, really flat planes. squares, saws, chisels, straightedges, surface plates (and even dibbles and spades and pruning saws and router tables and table saws), if not bench tops.
Re: New Machines
I think the stepper motor vises etc. are ......
Eric Hedberg
>too complicated and "electronic". How about some good old fashioned hydraulics? It would sure make it a lot easier to fit those tight joints. Talk about clamping force! I like the idea of precision ground gardening implements, but would we have to start arguing over which edge angle is appropriate for clay vs black loam?
Re: New Machines
Re: at last a metal jointer for Adam!
paul womack
Re: New Machines
Dan Clermont in Burnaby
>Curious to know what it weighs and whether or not you need a license to push it. Also wonder if it comes with a set of wheels to help you move it over to your workbench.
Dan Clermont
Re: New Machines
Rob Lee
>Hi Moses -
You put me in a tough position... if I said yes, then our mailbox'd full of planes.... :)
Honestly - your best bet is try a local shop first - if you leave it with them long enough, they can use it for fill in work...and the price won't be too bad..
The small grinders aren't that expensive (relatively!) - a 24" one would be 10K or so (the big ones, 80-100K), and pretty much any good metal shop would have one. If you enquire at a garage, they'd probably be able to point you in the right direction.
One of the problems you'll face with an older Stanley is - it's going to be a grey iron casting - and it WILL move after machining...
Cheers -
Rob
Re: New Machines
Rob Lee
>William -
Heaven forbid gardeners start measuring their tools .....!!
What is nice with the long bed (coupled with the auto-dresser) is that a bunch of stuff can be ganged up and ground at once.... say 4 22" planes instead of 2....
Cheers -
Rob
