Small, Bevel Up, High Angle, Krenov-Style plane...
Jonathan Kaplan (OR)
>Recently, I ran into a wood that I just couldn't get a handle on. I decided to use "flame birch" for this cabinet I�ve been in the process of making for almost two years. I bought the wood well over two years ago now, milled it to rough size before I moved, and started working it to final dimensions last month.
My trustyLN #4 wasn�t working on it at all. I�d sharpen the blade, tune it as well as I could, and I�d get massive tear out. I�d think my sharpening skills must be off, and grab a scrap piece of purpleheart, or bloodwood, or cocobolo, etc., and the plane would leave a beautiful, shimmering surface. Back to the birch � a mess. Card scrapers worked OK, but were very slow.
So I figured it might be time to move to a high-angle plane. For the fun of it, I decided to make a high-angle, bevel-up plane. The blade (a Hock) came ground at around 25*, and I mounted it on a 30* bed, for a total angle of 55*. After messing around w/ various tricky ideas for making it adjustable that didn�t work, I gave up and made a straight-forward Krenov style plane.
The good news? It works! I�ve been able to plane the wood w/ minimal or no tear-out, and the surface it leaves is at least as good as that left by scrapers. The bad news? Well, it ain�t pretty, but...
Thanks for looking!
jk
Re: Small, Bevel Up, High Angle, Krenov-Style plane...
One more pic...
>This picture gives a sense of the plane's size. It really is very small (note the block plane in the background -- it's around the same size)! But quite fun to use, I'm finding...
Thanks for looking!
jk
I think it's pretty...
Scott Burr in Ben Lomond CA
>Pretty cool. To whip out a plane like that and have it work out of the chute, great job! Nice looking spoke shave too!
Steve Kubien
Steve Kubien
>Nicely done! Gotta like the satisfaction of making your own tools, eh?
Steve Kubien
Ajax, Ontario - where it finally feels like winter
very impressive
John Pappas
>Great sense of victory, I am sure. Congratulations.
Lots of fiddling...
>Thanks! But it hardly worked well right "out of the shoot..." Even after I gave up on the adjustable mouth idea (don't even ask), I had to fiddle w/ the mouth opening, then blew it and had to shim the blade up a tiny bit to close the opening a tad (one piece of paper made the difference!), then finally got it cutting well, only to find that it was uncomfortable to hold, and so had to shave, file, and sand new curves into it, etc.
But, in all honesty, the cabinet project was at a very detail-y and stressful point, so taking a day off to play w/ a little plane was quite relaxing.
jk
Kinda had a feeling...
>It could never be THAT easy eh? Glad to hear it all came together though. So... the next one will should be easier right? Right...
Re: One more pic...
Angelo Schembari in Cornwall, NY
>Great job Jonathan! Yet another thing on my roundtuit list.
paul womack
That doesn't sound like a good mix for edge retention.
BugBear
Edge Retention...
>I admit to being a bit worried about the relatively radical angle, etc. But in past use the Hock blade had held up well to all kinds of abuse, so I figured it was worth a shot. So far, it seems to retain a nice, sharp edge through fairly long sessions -- keeping in mind that the plane was built to do 'final' smoothing, and not to remove a lot of material...
But I'll keep an eye on it, and post if I run into any trouble...
jk
