vaccum kiln pics and problems solved.
steve knight
Welcome to Adobe GoLive 6
Here is a picture of my vacuum kiln. This sucker had a real hard birth ad a lot of mistakes. First trying to get a perfect seal this was the first battle. Never did solve that one. So the pump has to run all the time. But I found out it needs to anyway so that problem was solved (G) second was heating it. I had these heating bars that were inside and worked ok but they were pretty uneven. I had an electric blanket that died. The new ones have 10 hour shutoffs. I had some under floor heating wire. The first roll was perfect and worked well on 120. But I had hacked it up for my first kilns and I could not use it again. The second roll I got was not the same. It only worked on 220 and the 50 or 60 feet I used at once got way to hot and melted the insulation off the wire. At 120 it kept tripping the 20 amp breaker.
I finally broke down and bought these silicone heating pads. It was 20.00 more each to have self sticking so I just used aluminum tape. They were spendy at about 50.00 each for 12x24. Though they are rated at 700 watts max they don�t seem to draw that. I bought these from MSC and got the recommended heating controllers. 80.00 Each and I needed two of them.
Well it worked fine for a bit. But one controller would help making the pads overheat. I had one replaced and the second did the same thing. It really pissed me off to spend that much and have them fail.
A couple people here helped me out and I got the right type of controllers. Variable voltage controllers. The two shown here were built for me and made practical. I am testing them right now.
The last part is a vacuum pump. Not any pump will do. You need one that will pull atleast 29� of vacuum. You also need one that can handle some moisture. Or you need to make a condenser to get the water out of the line or your in trouble.
But after all that is met you can dry wood. I start heating the wood really slowly over a several day period. Then I turn on the vacuum pump. I use this to only finish drying woods that are not dry enough and I take my time and don�t use too much temp. Usually a couple of weeks.
My first wood to dry is a 500.00 piece of ebony for Wayne to make infill�s out of.
Re: vaccum kiln pics and problems solved.
>It is a thing of beauty. ;-)
Where did you get the pump?
Steve,you are a wonder!
Bob Hackett
>It seems there are no limits to the things you will do(or are capable of)in order to make a better plane.
You are an inspiration to the rest of us.
Thanks for posting this.
Mainely,Bob
steve knight
>ebay of course (G) I had a great old one one guy gave me. but in working the bugs out of this the motor died. then I bought one and it did not pull enough vacuum so I had to get another one. I bid on this really good powerful pump on ebay I figured I would get outbid but nope I won it. but I have nto bought the oil for it yet to try it out (G) I had to buy the rebuild kit for this one so it could pull the max vacuum. since this is a dry pump a little water does nto really bother it.
Re: Steve,you are a wonder!
steve knight
>(G) well I do like to do such things. but one of the biggest problems with plane building I dry wood. I can't have wood over 2% too high in moisture content or the plane will crack. So I needed some way to get some woods down to where I need them fast. this project was a real battle becasue I never had enough money to spend to do it right. though in the long run I spent way too much.
Part of it is I don't have any extra money and never have so I ahd to figure out how to do it myself. I always wonder what I would do if I could afford to buy the things I need to do what I want.
Jim in Burlington Ont.
Jim in Burlington Ontario
>Steve I have never built one but work in a power and processing plant so maybe a few thoughts to perfect it. If you have a industrial insulation supplier to help hold the heat in. If you have a industrial junk yard around you might be able to pick up a large piece of stainless pipe with a flange on it to make for easy sealing. As for the pump running all the time you could install a vacuum switch to start stop your pump. We run 150HP vacuum pumps and prefer teflon tape for all joints and neoprene gaskets for flanges seems to minimize leaks.
Hoa Dinh in Alameda
>Steve,
I'm glad it works out for you. I've never realized it'd take so much time and effort and resoursefulness.
Learn something everyday.
-- Hoa
steve knight
>I had others insulated but I have had more of a problem keeping it cool enough (G)but it is nice to be able to feel the pads to keep track of what they are doing. I don't trust this setup enough (G)
I use a neoprene pad on the lid.
but I found it needs to run all the time or you can't remove the moisture from the kiln. it will just puddle up inside the kiln.
steve knight
>if I did it rigth the first few tiems it would have helped (G) but I did not spend ehough on it at fist and tried to do it the cheap way.
Tom Colligan, Peoria
>Steve, why do you need to dry wood? Wouldn't all the wood you buy - like us - already be suitable as is? Tia, Tom
steve knight
>I sure wish (G) ebony and cocobolo are the biggest problem. but what I need is a large wood budget so I can have wood sitting around for a year or more. lets see 200bf of ebony is only 13000.00
