holdfasts
holdfasts
holdfasts
mike muzzarelli
>How much oversize should I drill the holes for my holdfasts. Got a small and a large from Woddcraft and would like to try them.
Re: holdfasts
Re: holdfasts
>I have the same holdfasts. I just used a 3/4" hole for both but this was in chipboard and pine (my excuse for a bench).
If this is hardwood you might want to go a little bigger for the larger holdfasts but the small ones will work fine with 3/4".
Re: holdfasts
Re: holdfasts
Michael Stadulis, in Gloucester County, NJ
>Hi,
The hole should be just slightly larger in diameter so that the holdfast slides up and down without any effort at all. You don't want any friction, so I'd guess that the bench holes for mine are 1/8 to 3/16" greater in diameter than my holdfasts. As soon as you whack it down on something, it will lock up.
Mike
Re: holdfasts
Re: holdfasts
David Miller from Iowa
>It also depends upon the thickness of the bench. Try a test case first
