cutting dovetails on long boards
Jeremy Osner
>Dovetails cont. The other day I posted about the pins, now yesterday evening and this morning I cut and chopped out the tails. I ran into an issue I had not anticipated, namely: the boards with the tails on them are quite long, 62" which is about my eye level or a little higher if they are standing on the floor. I am used to cutting with the work at about my belly or chest level. So what to do? On the first set of tails I stood the board up straight and cut at my eye level; that was pretty uncomfortable although the tails came out fairly well. Second time around, I leaned the board over so that the top corner of the board was about at my chest level (i.e. the board is leaning into my face vise). This was a little weird at first but the cuts went very quickly and were accurate. Anyone have any other solutions?
I am getting the angle of the tail right as follows: first I cut with my saw almost flat against the face of the board, tracing the marked angle (marked with pencil), a couple of strokes so I have a notch I can follow, then I rotate the saw so it is cutting the end grain and follow the notch I made.
