Technic tips? Shaping a bowsaw handle by hand.
Dave (Arlington, VA)
>Hi all -
I sure could use some advice. I'm in the process of making a bow saw, and (most) everything is coming together nicely. The one area I'm having the most difficulty with is one that might surprise you -- the handles. I'm making the bowsaw out of black locust (including the handles) from trees that fell in our yard during Hurricane Isabel - Sept 2003.
I don't have a lathe - and I don't have a drill press. The lathe is not a problem - ordinarily - as I have made a fair number of socket chisel and file handles just by hand using files, rasps, spokeshave, drawknife and sandpaper.
My problem is that I can't seem to drill the hole for the brass rod (aka eventual blade holder) straight enough - and then figure out how to shape the handle (relatively symetrically) around the axis of the hole and the brass rod.
Any suggestions? They'd be MUCH appreciate. I've gone through three handles so far (now kindling) and am working on my fourth - with nothing useable to show for it.
Thanks -
Dave
P.S. I'm not really interested in buying a lathe or drill press. Looking for a pure hand tool solution. I just don't have the room in my tiny little shop.
