Chisel Honing Guide
Roberto Perez F
>I saw this Chisel Honing Guide in www.garretwade.com and will like to know from the experts their opinion.
Chisel Honing Guide
Roberto Perez F
How's about a little more...
Scott Burr Ben Lomond,CA
>Info here Roberto. Lots of guides on that site, witch one are you speaking of?
Re: How's about a little more...
Roberto Perez F
>Sorry, the picture was not loaded
if that thing works as good as...
John Longwitz-Doraville, GA
>...it looks it should be a darn sight better than most I've seen.
Re: if that thing works as good as...
david charlesworth
>The guide is well made. I find it works better if the wheels are supported on strips of ply/acrylic etc.
This increases the projection of the chisel edge, which makes honing more comfortable.
Without wheel support, the small projection is very awkward for narrow chisels. I had to use a pencil with eraser to put pressure on the blade tip!
David Charlesworth
It works O.K...
>It's for use on waterstones, scary sharpening will tear up the wheels DAMHIKT. It was designed to hold Japanese chisels. It can only hold chisels up to an inch if I remember correctly (I think a larger version of it as available. It's a bit awkward to hold on to, but it holds thin chisels well.
Another one coming...Rob?
Tony - Memphis
>Seems like I recall that Lee Valley is working on a new model? I've been waiting patiently! Something to keep in mind. I've been using their current model and had real good luck with it.
Tony
