ADVERTISE HERE - FREE TRIAL
Sharpening, ad nauseum
Gerry Doll
>1. Pursuant to my research, a 6000 water stone is of significantly finer grit than 2000 grit sand paper. Yet, when moving from SS to waterstones, I find that my 6000 grit stone is leaving a dull mat finish. Whereas the 2000 grit SC paper left a mirror polish. Am I comparing apples and oranges or is there a fault in technigue, (flattening WS w/ 1000 DMT, building slurry w/ nagura)???
2. After making a hash of a couple of plane irons whie attempting to flatten backs (apparently put to much pressure on end of blade and ended up with substatial back bevel), I ground the blades down past the back bevel on my $15.00 grinder. Not art work by any means. Did not get ends completely square, but figured it would straighten out while honing on 150 grit SC paper. Using an Eclipse style jig, I ended up with a convex profile. Honed some more, still convex. By my reckoning, the jig should produce a straight edge eventually, BUT IT AIN'T HAPPENING?? Any thoughts?
Gerry,
Thinking tailed-beasties may not be so bad
Re: Sharpening, ad nauseum
Rick Hoppe (Los Angeles)
>Gerry, my thoughts:
1) IMHO this is a kind of apples and oranges kind of thing. The equivalency charts are all over the map. It's been my experience that 2000 grit paper is roughly equivalent to 8000. I think the grit on the paper breaks down more quickly than the stone and also the surface of the paper becomes burnished rather quickly, rendering the tool more polished than with the stone.
2) A 1 degree back bevel on a plane blade is OK (not OK on a chisel). As for the curved edge, when flattening backs it really pays to flatten the stone FREQUENTLY. David Charlesworth says after every 100 strokes. I just check the stone regularly with a good straight edge. Much of the time a slightly curved edge is a good thing (if the curve is created on the bevel side.
Jim in Burlington Ont.
Jim in Burlington Ontario
>Shiny is not sharp. No matter what stones you use if your technique is bad it needs work. See if someone can show you a technique if not I would reccomend would be David Charlesworth video. Sounds to me like your rushing the whole process.
Gerry Doll
>The slight convex profile was originally from a pi$$ poor grinding job. I assumed the profile would loose it's convexity if honed on plate glass w/ 150 grit SC. There's the rub. The convex profile is still there, just smoother now.
My thinking was that any irregularities from a perfectly straight edge left from the grinding would be corrected when honed using an eclipse style jig on plate glass. This does not appear to be the case. Wouldn't honing with eclipse eventually wear away the convex profile??
Gerry Doll
>Jim,
With the amount of time I've spent with plate glass, reams of sand paper, cans of spray adhesive, razor blades, cans of adhesive remover, and flattening waterstones, I don't think I'm rushing anything. As a matter of fact, it appears that my progress has been more of a crawl. A learning experience, but so is one's first prostate exam.
Gery
tired of blowing metal dust from his sinuses
Re: Sharpening, ad nauseum *LINK*
>Gerry The rushing part is when you are sharpening you take a few strokes wipe it off and have a look. When using a jig it's all finger pressure. It's very tough to describe sharpening yet easy to show someone if you only you lived closer. There is a little tutorial on LV site just go down to instr highlighted in blue and have a look thru maybe it will be some help.
http://www.leevalley.com/wood/page.asp?page=33001&category=1,43072,43078&abspage=1&ccurrency=1&SID=
>Gerry, the Eclipse style jig has a very narrow roller the jig rides on. This makes it very responsive to finger pressure along the edge. Ergo, this is a jig that may require a little more skill to control if what you want is a straight edge. The Veritas with its wider roller is more stable and, I think, easier to achieve a straight edge.
You sound a lot like me when I started sharpening. I had a tendency to overwork each stage especially the final honing part. It�s a drag being on the uphill end of the learning curve.
I agree with Jim. Get the Charlesworth video.
paul womack
Not according to this reference.
grit size comparison. If this chart is true, they're comparable.
...straighten out while honing on 150 grit SC paper. Using an Eclipse style jig, I ended up with a convex profile.
This is a known issue with sandpaper, especially if not glued down. SiC wears quite quickly, it tends to wear more in the middle; further the swarf builds up more in the middle.
The result is that the centre of the paper cuts less well than the edges, resulting in a crowned blades. The effect is less pronounced in finer grits, so I tend to just let it happen, since I normally desire my blades crowened to some extent.
If you want a straight blade, use wide, fresh SiC to reduce the 2 effects described above.
This issue also applies to plane sole flattening by lapping, both side to side and end to end, resulting in convex soles.
BugBear
Brent
>Gerry
It may well be that the crucial part of your problem is contained in the phrase "honed using an eclipse style jig on plate glass".
Before you try anything else, put the blade into the jig as you normally do the put a straight edge across the back of the blade. Did tightening the jig bend the blade?
I noticed this way back when and it started me off on devising my jig for holding plane irons. Check out the link to my pages on plane iron sharpening and testing.
Brent
http://www3.telus.net/BrentBeach/Sharpen/jig.html
