Bench Hook
Bench Hook
Bench Hook
Patrick Gibbons, Spring Branch, TX
>Just finished making a bench hook. Used 3/4" stock for all pieces. Should I have used a thicker piece for the fences? This is for sawing tenon cheeks predominantly.
Re: Bench Hook
Re: Bench Hook
Rick Hoppe (Los Angeles)
>Patrick, correct me if I'm wrong, but I think you mean tenon SHOULDERS.
Most fences are just a tad thicker but, 3/4 in. should work just fine for most applications. Test it out. If you can hold the stock securely while you cut, you've got a good, working bench hook.
Re: Bench Hook
Fine
David Miller from Iowa
>Should work fine, bench hooks aren't too fussy. Fun to make too if it ever fails you.
Re: Bench Hook
Re: Bench Hook
>Yes I did mean shoulders. I've been using it all day today and it seems just fine. Should have waited a few hours and probably wouldn't have asked the question.
Re: Bench Hook
There shouldn't be much stress...
Tim of Dublin
>applied to the fence. If so, your saw needs a sharpening (or a new blade if you use impulse hardened blades).
My hooks are made of 1/2 to 3/4 thick stock but the fences are all very low - around 1/2 to 1/4 inch proud of the bed.
Tim
