dovetail video
dovetail video
dovetail video
rocky eulo
>I'm looking for a good video on cutting dovetails. I've never cut any before so it will have to be a video for beginners. Thanks in advance.
Rocky
Re: dovetail video
Re: dovetail video
>Hi Rocky
There is nothing quite so satisfying (in woodworking ... please!) as handcut dovetails, so goodonya!
I have experience with three video teachers, and found that all of them provide very helpful info - but you may need to watch the videos many, many times to appreciate the subleties that they forget (or are not aware of the need) to explain.
In order of preference:
1. Rob Cosman - more technical than the others, but he does provide strategies more explicitly.
2. Frank Klausz - more relaxed, but also so much is non-technical and just reflects his many years of experience.
3. Tage Frid - just nice to watch a master at work.
There is one other (British) but my mind has gone blank - too close to the holidays!
Re: dovetail video
Jim in Burlington Ont.
Re: dovetail video
Jim in Burlington Ontario
>I have the Rob Cosman video and Frank Klauz also. Rob teaches you how to lay them out and make very high quality joints and frank teaches informal flow. If I had to get one it would be Rob Cosman's.
Re: dovetail video
Jack Guzman from Maine
Re: dovetail video
>I have all three of those videos Derek mentioned and I totally agree. Also I would recommend the booklet The Complete Dovetail by Ian Kirby. His lessons helped me get started.Dovetails are simple to make.I think the main thing is to learn to saw to a line.Kirby helped me with that.
I'm a former mechanic and a carpenter. My woodworking is still pretty crude. If I can learn to cut dovetails,anyone can.---Jack
Re: dovetail video
Re: dovetail video
Pam Niedermayer - Austin, TX
>The British one is Jim Kingshott, my favorite; but our 2nd and 3rd choices are the same. Frank is only second because Kingshott has that certain something that I find attractive, a precise, easy-going work ethic.
Pam
Re: dovetail video
Re: dovetail video
Dan Clermont in Burnaby
>I have only seen the Cosman video and was very happy with it.
I haven't seen the other videos listed so I can;t comment on them.
Dan Clermont
Re: dovetail video
Re: ditto the Kirby book - superb!
paul womack
Re: dovetail video
Re: dovetail video
rocky eulo
>Thanks for the advice. I'll probably start out with the Cosman video and go from there.
Rocky
Re: dovetail video
recommendation
bill tindall
>First, realize that there is a world of difference for most of us between cutting dovetails occasionally and regularly/professionally. The occasional cutter needs a technique that is easy to master, remember, and more fool proof. Productivity is greatly less important, and experience is lacking. For these reasons, the Klause approach is a nice show but not for beginners. I would say his approach actually can be discouraging to beginners.
On the other hand, our club teaches classes based on the less intimidating Cosman video and students have great success on their first tries.
This question raises an issue. I think that there are woodworking operations where the approach a professional uses can be different from that better suited to a beginner. So beginners should be wary of advice they get from professionals as it may not always be the best place to start.
Re: dovetail video
Re: recommendation
>I don't see anything intimidating about Frank's dovetail cutting. On the contrary, he makes it easy, which, in my opinion, is a reflection of reality. I think the real problem is that most people make more of the task than is necessary.
What could be easier than cutting tails, marking the pins based on the tails that are already cut, and cutting the pins?
Pam
Re: dovetail video
Are we talking about the same Frank?
Dan Donaldson
>Or did he change his mind. I took a seminar from him some time ago, and at that time, he was adamantly pins first ;-)
Re: dovetail video
My bad
>Whoo, what tricks memory plays. I hadn't watched it for more than a year; so tonight I watched again. Sure enough, he does pins first. I think the advantage to this suits his marking methods, much easier to line up the edges of the boards when the whole board is present.
My previous message was a reflection of how I do it, my interpretation of his process.
Pam
Re: dovetail video
Re: My bad
paul womack
As a matter of linguisitcs, I'd have said changing pins first for tails first is a little beyond "interpretation". What distinctive aspects of his approach do you retain and recommend?
BugBear
Re: dovetail video
Re: intimidation
paul womack
The only intimidating thing about Rob is the aggregate cost of the tools he says you "need".
BugBear (happily cutting DT's with a home brew cutting gauge, a self sharpened and tuned DT saw, and a Ward and Payne chisel)
Re: dovetail video
Re: My bad
>I disagree, I just don't think it's a big deal which is done first. I freehand the tails like he does the pins, then mark the pins from the cut tails, cut on the waste side of the lines, glue (I'm trying hide glue instead of his white), and assemble. I also chisel the waste much like he does. However, it's probably easier to mark the tails from the cut pins than the reverse; so it's likely Frank's method is a bit more efficient.
I understand that when doing half blind dovetails it's easier to do one or the other first, can't remember which, as I don't routinely do half blind dovetails as yet. Again, I follow Frank and front the drawers with another piece of wood, so half-blinds aren't needed. This may change if I ever start doing period pieces.
Pam
Re: dovetail video
Re: recommendation
Charles
>Explain your tails first methodology on tall case sides please.
Re: dovetail video
Re: recommendation
>I haven't done any tall case sides that need dovetails, only utilitarian entertainment centers in closets, kitchen cabinets of plywood, and the like. The bigger pieces I care about have been desks, tables and rocking chairs, no dovetails required (well, some sliding dovetails were used, but I'm assuming they don't count for this discussion). The smaller pieces in which dovetails have been used are drawers and boxes.
So, Charles, what's the importance of pins first on tall case sides? Is that what you do?
Pam
Re: dovetail video
Re: recommendation
Charles
>You owe it to yourself to build a large carcase piece with lap dovetails. Then you can answer your own question.
Re: dovetail video
Re: recommendation
>And is this because you clearly haven't built a large carcase piece and can't answer? See, I don't need to invent tasks simply to answer your questions. We're not in class here.
Pam
