Grit comparison to waterstones, a bit long
Sanford Levy
>Hi. I am wondering about grit comparisons between japanese waterstones and American grits. One source I have says that a Japanese waterstone 1000 grit is equal to a US 500 grit, but another source says that the "Japanese JIS-grade" (which I assume is what is used for their waterstones) is equal to US 600. The reason I ask about the comparisons, however, is not just this inconsistency. I ask because I have had very good success flattening plane irons and chisels using wetdry sandpaper stuck with water to a granite block. When the paper seems a bit used up, I just sprinkle on some silicon carbide powder of the same grit. The silicon carbide is a lot less expensive (from Kingsley North) than the sand paper so it is cost effective and works pretty well. But my silicon carbide powder only goes to 600. Rather than moving to expensive sheets of finer sandpaper, I was thinking of then moving to my 1200 King waterstone. But when I do this, the half shined plane or chisel back becomes far less well shined, which suggests that the Japanese 1200 is less fine than the american 600. But that does not seem to match what I have read. If the 1000 waterstone is equal to either 500 or 600, the 1200 waterstone must be finer than my 600 sandpaper or silicon carbide powder! I am confused about all this. (I was also surprised to see one chart say that 6000 waterstone is equal to 2 microns which makes it less fine than the .5 micron paper I have been using for honing a final edge!) Any information about this would be much appreciated. Sanford
