block plane purchase
rocky eulo
>I'm looking to buy a block plane to replace the $10 one I bought at Lowe's. This will be my 2nd plane(I own a LV med. shoulder). I've been looking at the LV's and LN's and am wondering if I should go with a low angle or standard block plane. I know the low angle is better for end grain but what about other areas. Any info would help. From what I've read in the archives both the LN and LV are good quality tools but any opinions on your favorite would be appreciated. Thanks.
Rocky
Re: block plane purchase
>In my opinion, the LN #140 would be a versatile plane to have. I have the Stanley #140 and don't use it a bunch because I have so many other block planes, but if I only had one it would be the one I'd want to have. You can buy an older Stanley #18 or #65 and have a pretty nice plane for quite a bit less than a new LN or LV, and it can function about the same with a new Hock iron. I have not really made up my mind over low angle planes, they are slightly better at shaving end grain, and I would probably buy the low angle before the standard angle for this reason.
Re: block plane purchase *LINK*
>Rocky
A low angle (LA, 37 degree cutting angle) block plane is far more versatile than a standard angle (SA, 45 degree cutting angle). The lower the cutting angle, the easier it will cut end grain. I have included a Link below to a recent thread here.
But there is another factor. It is easier to alter a LA block plane to cut like a SA (and even a HA) block plane. All you have to do is grind a steeper bevel on the blade. Keep a few extra blades on hand, and you have a versatile hand plane that can plane between 37 and 60+ degrees).
For my own use I mostly turn to a Stanley #65 with a Hock blades (LA), a Stanley #18 (SA and HA) or a LN bronze #102 (LA). And the LN is the one I generally grab first for tweeking. I do own a #140, but it is reserved for cross grain work, which is where it scores best.
Link to "5 minute experiment"
Tony - Memphis
>I can't offer any comparison's, but I have the LN low angle bronze job and I love it. Great little plane.
Tony
rocky eulo
>Tony
I just ordered the bronze 102 from LN this morning. The LN dovetail saw also happened to jump into the order (I'm not sure how that happened). I'm looking forward to working a little quieter in the shop.
Rocky
Thanks for the responses.
Dan Clermont in Burnaby
>I prefer the Low Angle as well. YOu can always get a second blade and change the bevel angle so it acts as a standard or york pitch blade.
I like my LN 60 1/2 but also have the 102 on my CHristmas list.
Good Luck,
Dan Clermont
John, NY
>I think you made the right choice. I have both LN LA and SA and also the LV LA. I find the LN LA is my goto block plane. The LV I find a little large [and I have quite large hands] but otherwise excellent. I use it with the optional larger handles from time to time.
