A small revelation and a question
Paul Kierstead
>While using planes today, I noticed they seem to be dragging a lot, so I put some more Waxlit on them. This seemed like far more hassle then it was worth, so when visiting the local home hardware I asked if they had sticks of wax, he sold me some paraffin wax (for sealing/candles) and what a difference!! Rub a little on the sole, the plane gliiiiiides. Wow. I did get something out of the Sharpening and Planing video (Rob Cosman) after all.
But it does raise the question: Is enough wax deposited on the wood to interfere with finishes, especially if you go from plane to finish (i.e. no sanding)? Finish here would be oil (Tried & True or the like) or Shellac.
Re: A small revelation and a question
>I use furniture wax - grab a paper towel, put a little on, rub it fiercely around, and I'm done. I tend to do several plane soles at the same time, when I'm organized, which saves on the hassle.
I've never had any trouble with the long-oil varnish (aka Danish oil) I most often use.
Paul Kierstead
>Thanks for the confidence! I like the paraffin much better then furniture wax as I can just smear some on right when I pain; no rubbing, etc. Of course, paraffin comes off much easier as well as it doesn't seem to harden and this is where my concern lies.
I use it all the time...
Scott Burr in Ben Lomond CA
>and I've never had a problem with it and oil or sheallac finishes
Re: I use it all the time...
>Do you think perhaps the solvent(s) in thouse finishes disolve the paraffin enough so that it is not of consequence?
Maybe...
>Never thought of it that way, may have to look into it.
The amount of wax used is never a lot, just a scribble down the center of the plane, when needed.
Re: Maybe...
Paul Kierstead
>Thank you for the answer. If you aren't worrying about it, not a lot of point in me doing so :)
Re: Your welcome...
Paul Kierstead
>Well, Rob is a pretty out going, nice guy, but... I gave it some thought. In his live demo's, in particular, he uses *lots* of wax. He planes something and hands it around to let you feel it's silky smoothness. Now it certainly would be good for his business if the wood was waxed, and he certainly isn't finishing those demo pieces. So although I respect his abilities, I try to keep my eyes open to his end goal... but I have to admit, a little paraffin sure does help.
R.J.Whelan
>Paul .... I, too, have never had a problem with wax contamination; I don't think you'd want to use automotive wax (silicone) but I've used parafin and beeswax for years with no noticable problem.
I have an old piece of carpet (5" x 15") glued to a piece of wood. I rub the carpet with a block of wax every now and then to charge it and when I'm planing I just drag the plane backwards over the carpet every few minutes. Makes a nice soft place to set the plane when I'm not using it too.
Greg Sloop, Portland Oregon
>Neat idea.
Thanks!
