Help me get started
Help me get started
Help me get started
David Miller from Iowa
>by giving me some conceptual ideas...
I have a need for a giant spoke pointer � like one that can handle 3+� diameter. I do a lot of round through tenons for bench, bracing, chair and table legs and I have a great 2� diameter hollow auger. But it is really hard to start and when I point the piece by hand I have a hard time getting the tenon perfectly centered. Yes, I can get it with careful layout and spokeshave work, but it is so easy when I do this at a smaller scale - just a few easy turns with the spoke pointer and the hollow auger starts easily and is right on center. I have never seen a manufactured jumbo spoke pointer, so I presume I�ll have to make one.
Ideas?
Thanks, David
Re: Help me get started
Jorge Castaneda
>How about a pole lathe like bodgers do?
Jim in Burlington Ont.
Jim in Burlington Ontario
>Why not make one I have seen a Program of Roy Underhills where he makes them. Seemed like a fairly simple project.
>Oystermen on the Delaware and Chesapeake used to have them, like a huge pencil sharpener, for sharpening cedar stakes (tree trunks) to mark the corners of their beds out on the bays. They'd probably handle a 6" diameter stake. You don't see them anymore, because nowadays, they just use PVC pipe, and wash them into the mud of the bay bottom by pumping water down through the pipe. I could ask around Port Norris, and see if anyone still has one that's not in a museum.
>Thanks - but I missed that one. What I am asking is how to make one?
>Thanks -
How did they work? Like a spokepointer in a brace, just bigger?
>Underhill has a how to make a rounding plane on his site. Well they are very similar only the blade has been set on a angle like a pencil sharpener. As for the case it looks just like a screw box and used the same way.
Witchet
Jorge Castaneda
>Hello William,
Your port reminded me of a gadget used to make oars, the witchet or is it widchet? That is quite portable and would do what David needs.
Re: Witchet
>Hmmm? Google can't find it for me, using either of your spellings or a couple of others I tried.
The term widget is close, but it is a generic term for just about any thingamajig, gadget or whatchamacallit, so that doesn't help either.
Maybe Bob Smalser can help us out?
Re: Witchet
Skip in Falls Church
>The construction of a witchet, rounder plane or stail engine is shown in Wooden Planes and How to Make Them by Perch and Lee. It's designed to take roughly round stock and make it round. Something I'd like to actually make some day.
Skip
Pointing up
Bob Hackett
>The bar none easiest way to point something quickly is to just use a hatchet and stump.
If you want a lead to making a dedicated rounding plane then I can forward one to you as I have one bookmarked and have no idea how to post a link to it.
Seems like an awful lot of work to make one when a hatchet will work just fine and doesn`t require a vice.Just my.02.
Mainely,Bob-Who`s sounding strangely like Todd in this post.
Re: Witchet or widget
Jorge Castaneda
>william,
as Skip says, the witchet is a rounding plane, there is a picture of one and a brief description of it in John M Whelan's book The Wooden Plane, page 165. He mentions both spellings.
Machete!
Jorge Castaneda
>Bob,
agree that the hatchet is a good tool for the job, but a machete is even faster.
Adapting to specialized tools
Bob Hackett
>Now that you mention it Jorge,I perfer a kukri over a machete.A long time back I noticed that one of the NCOs I looked up to carried a strange old crooked knife instead of a machete or a billhook.He could work more quickly and with less effort it seemed and best of all it fit perfectly between the frame and the ruck and could be drawn from and replaced to it`s sheath in a flash.He explained that it came from India and was called a kukri.After using it I was hooked.
Now I`m happy to introduce new NCOs (and anyone else who`ll listen)to this highly underrated and powerful tool.It offers more power and control than a machete or billhook for alittle less money.One of the few low priced items coming out of India that I`ve been impressed with.
Glad you mentioned it,I hadn`t thought of Sgt. Larken in awhile.
Mainely,Bob
>Thanks for the reference, Jorge.
David, I think you need to look at that chapter of Whelan's book. It shows lots of different possible solutions to your problem.
Kukri !!
Jorge Castaneda
>Bob,
Thanks for reminding me of that one, I've seen it in action too and was very impressed. There is a store in Blue Hill that carries them, they say they are made of old leaf springs.
Uhmm, I'll put it in my Christmas wish list.
Thanks
