refinishing question
Howard Pollack
>I have an old mahogany coffee table with a figured veneer top that I'd like to refinish. The finish on top is scratched, cracked, and has a small spot where the finish looks burned through (cigarette for just a moment too long?). Should I attempt to remove the old finish or try to put a couple of very thin coats of shellac on it to build a base for a couple of thicker coats which I could rub out? If I should remove the finish, what is the best way to do so? I'm not sure what that finish is, I suspect that it may be lacquer- it is clearly a factory made piece. Thanks -Howard
Re: refinishing question
Barry Va Beach
>Howard, I am not the best person to answer this but I'll take a stab. First, you can determine the type of finish by using qtips dipped in diferent solvents in an inconspicous place. Start with denatured alcohol, if that dissolves the finish, it is shellac, if it doesn't then try lacquer thinner, if the finish dissolves, it is either lacquer or water based, the age of the piece rules out water based finishes, if neither dissolves the finish it is a reactive finish such as varnish and you won't be able to dissolve it with a common solvent. If you can dissolve it with ( either denatured alcohol or laquer thinner) you might want to try pouring that solvent in a container and then dipping a pad in it and then rubbing the finish lightly, wringing out the pad and then rubbing the piece - in essence you dissolve the existing finish and spread it around again. If you are happy with the result, you have saved yourself a ton of time. If not, I suggest buying " Understanding Wood Finishing " by Bob Flexner, it is the bible in my opinion. Good luck
Pam Niedermayer - Austin, TX
>Flexner's video is also very, very good.
Pam
"Conserve"/"Restore"/"Refinish" *LINK*
Bob Smalser, Seabeck, WA
>Great answers below.
When I was doing this, I preferred a minimalist restoration approach....save all the original finish you can because it's historically correct and it saves work.
It's much harder to correct ham-handed, amateur repair/refinish jobs and my link below also addresses that.
Make any mechanical repairs first. I like to leave all marks of honest use but repair the abuse. Your choice how far you go, but I generally leave minor burn marks, ink stains and scratches in. But I have also spliced in new veneer aged/dyed to match the old (difficult) and filled scratches with shellac stick or these days...thick cyano glue.
Then I use a solvent that only removes the deteriorated layer of finish on 0000 steel wool and spread the deteriorated finish onto any new repairs to match the color.
Then I simply topcoat with a compatible finish...lacquer or alkyd varnish....never, ever poly.
My goal is to make the piece appear it is its actual age but has been well-cared-for instead of abused.
Constantines used to make veneer repair punches that did both male and female pieces with a hard-to-see irregular edge. Nice to have, but spendy. But you can duplicate the technique with an Xacto knife and some practice.
Matching new wood to old often requires bleaching the new wood first, then dyeing it as close as you can get, then often coloring the entire topcoat.
Good luck....hope these help you.
Restoring Varnished Hardwood
Also in WC articles
Dan Donaldson
>Thanks to Bob, this article is also in the WC articles section.
Thank you
Howard Pollack
