LV MKII Sharpening System (QPSS)
John Meikrantz
>How does the MKII handle short or narrow blades? Will it work well for example with blades from for example a Stanley 50, spokeshave blades, or 1/8" chisels?
Thanks,
John
Re: LV MKII Sharpening System (QPSS)
Re: LV MKII Sharpening System (QPSS) *LINK*
John Todd
>I use the MKII on narrow chisels with out much problem. To hold very short blades/irons, such as with spokeshaves, use the LV small blade holder that also works well with the LV honing guide and angle jig
Veritas Small Blade Holder
Cool idea, I hadn't seen that before
Todd from San Jose
Mike in Mystic
>Hi John,
Are you saying you use the small-blade holder in conjunction with the MKII? I emailed LV tech support and was told NOT to do this (although I haven't had a chance to test it out). I don't really remember exactly why they said this, but probably since the blade is only secured with magnets they are concerned it might fall out and be thrown by the turning platter.
Anyway, if you've used it this way (and I admit to having planned to try this myself) it would be good to know and if you have any issues/suggestions.
Mike
You might try this  *LINK*
Dan Donaldson
short blade holding
John Todd
>Since I never asked tech support if it would work, I didn't know they didn't recommend it! I can understand the safety issues now that I think about it AND I intuitively was always VERY careful to not press the iron very hard into the spinning platter. It does work for honing.. probably wouldn't be so safe for sharpening. I use the small blade holder far more often on a glass plate with automotive sandpaper.. scarry sharp. But I have used it on the MKII.
Using a plane iron and chip breaker, as mentioned in another post would probably be a safer method which I'll probably try.
