Planing a square edge (long).
Paul Kierstead
>OKOK, hardly a new problem that has never been discussed before, but WTH I am going to bring it up again. Prepping stock by hand is getting increasingly easy; I now rarely shy away from boards wider then my jointer as I don't mind flattening them my self. I happily trim true TS and BS edges; Actually, I am finding my "person tool heaven" to be a Bandsaw, planes and thickness planer (lets face it, thicknessing by hand isn't the most fun thing in the world). But getting a square edge, particularly and edge which requires a lot of planing, ah...pain. Methods I know of:
1) Use lateral adjuster. Works OK for getting the blade square to the sole, but is kind of coarse and I have not had a good experience with it to "correct" an edge.
2) Use a shooting board. I have one I use for board ends and it works quite well, but shooting a long board this way (or wide panel) would seem to be troublesome. I guess I could make a huge one and try it out, but I have doubts...
3) Try adjusting pressure on the plane. I couldn't make this work.
4) Use one of those squaring thingies, such as this:
http://www.leevalley.com/wood/page.asp?page=41716&category=1,41182&ccurrency=1&SID=
Hasn't worked out so well. With a heavy plane, it is kinda hard to keep the fence against the board square; maybe I just need more practice with it?
5) Use Jeff Gorman's method of a convex blade:
http://www.amgron.clara.net/planingpoints/edgeplaning/squareedgeindex.htm
Now this one intrigues me, but I have reservations. For one, I am not so sure that the absolute plane control required can be had anytime soon (looks like a *lot* of experience required). Secondly, I normally do glue joints using the two boards face-to-face method, which works extremely well and I am loath to risk by having a convex blade. Maybe I could do it on my Jack plane and use it to "true" the edge and then finish with a square bladed jointer. I ain't buying another #8 anytime soon so I have have both available...
Any help or input would be greatly appreciated. Or just sympathy :)
