Cradle project
Cradle project
Cradle project
Steve S., Coastal GA
>Hi everyone,
Recently some close friends of mine had their first baby. I've done a few regular through dovetails, but I've always wanted to try a project with angled dovetails. This was my first go at it. The layout's a bit more tedious but fairly simple. Otherwise the cutting and chisel work is pretty much the same as regular through dovetails.
The design is mostly my own, based on some dimensions from a free plan on the web. The wood's bigleaf western maple, with a bit of fiddleback figure I picked up for pretty cheap. Finished with honeytone amber dye stain from Lee Valley followed by 3 coats of a wiped on varnish/oil mix.
Steve
Re: Cradle project
Cradle project - footboard end
>End view of dovetails. BTW these are the first pics I've done here, is it possible to put multiple pictures in a single post?
Steve
Re: Cradle project
Pretty doggone fine
>What an outstanding baby gift! I predict you're going to get to hold that baby whenever you want.
Re: Cradle project
Re: Cradle project
Robin Frierson
>Looks like you now have an heirloom cradle. Very nice job, one you should be very proud of.
Re: Cradle project
Re: Cradle project
>Very nice! The idea of laying out angled dovetails makes my head hurt. They look like they came out quite well.
Re: Cradle project
Jim in Burlington Ont.
Re: Cradle project
Jim in Burlington Ontario
>Fantastic great gift
Re: Cradle project
Beautiful; prodigious even!
Alan Hamilton
Re: Cradle project
The layout trick...
>I started with squared up ends, then cut the angles (15 degrees in this case)and save the wedge-shaped offcut pieces. Scribe your depth lines like you normally would. Then layout the tails but instead of referencing your bevel guage against the end of the board use the offcut piece to register the guage. This way your tails will extend out parallel with the grain instead of perpendicular to the end like with some goofy router jig would do. Cut out the tails, then use them to mark the pins on the end grain. Once again use the offcut to reference your square and carry the pin lines down to the scribe line. Cut and chop the pins and you're set.
If that's clear as mud a pic makes it easier to understand:
Re: Cradle project
layout pic
Re: Cradle project
Mutiple pictures
Dan Donaldson
>First, very nice cradle. The DT's look great.
As far as multiple pictures in one post, here is a link to the faq. There is a question that describes how to do it. The main thing is that in order to post multiple pictures, you must get them up to a server somewhere, either on your own website if you have one, or on one of the free or low cost ones out on the web. Be aware that some of the free ones limit the number of views per hour or day.
Re: Cradle project
Aha! Thanks for the explanation.
Re: Cradle project
Very nice work. Lucky Friends:)
Victor Parisian
