ADVERTISE HERE - FREE TRIAL
Contents of a working cabinetmaker's toolchest
Andrew F in Australia
>Hi all,
I had to knock up a quick toolbox/chest because I got sick of having to take 5 items out of my old toolbox to get to the one I needed.
Attached photos are of all the tools I use routinely (at least every three months).
In all honesty, the most used ones are
3" layout square
marking knife
6" multigrips
plane (No6 used for 99% of all work)
screwdriver
6" rule
safety gear
dovetail saw
marking/cutting gauge
I use a sliding table saw for the big cuts, or the tenon saw, depending on how I'm feeling or what time of the day it is (or evening if I'm working late). The other saws are there for a small cut when it's not worth going to the saw and setting up/turning on (or if we have an extensive blackout, as has happened.)
This is, I'd suggest, all that's needed to do most things - I've not included the following because they're powered.
drills
grinder
trimmer/router
Anyway, this is what I get by on day-to-day ... anything else you guys use often that isn't in here?
Cheers,
Andrew
Re: Contents of a working cabinetmaker's toolchest
toolbox contents laid out on bench
>Here is all that is in the box
gauges - cutting mortice and marking
Hammers, mallets, plane hammer, bradawl, tack pull
Layout tools - squares, marking knife, sliding bev
>layout tools - squares, 18 inch straightedge, sliding bevels, marking knife
misc tools - pliers, sharpening stones, sandpaper
rules
planes, scrapers, etc...
safety gear, files
Saws
wax and buffing compound (used for stropping edge
toolbox packed and open
toolbox closed
Layout of end of toolbox, along with mistake
>never layout and cut joinery late at night - I fitted the lid backwards on the scrapped end
Chisels (also used daily/hourly)
>Forgot this one on the list
Chisel till - closed up
Tim of Dublin
>pencil, chalk, paper.
I need a sketch of some sort with at least the overall dimensions I'm shooting for.
Need the chalk or grease pen or similar so I can mark out the rough cuts on a board.....don't know about you but I seldom can find lumber that is sawn parallel to the grain....and sometimes you want the grain at a certain angle.
Jigsaw - cutting out the rough marked pieces.
drill - powered or hand. Much cabinetry has metal hinges and other hardware.
Ink or chalk lines are helpful too.
Thanks Tim
>I've got a drawer full of pencils chalk and a pencil rubber in the toolchest (behind the square).
I agree with what you say there.
Cheers,
Andrew
Sargent V-B-M Tool Cabinet - 1911
L. Hanson - N. Idaho
>Thought these were interesting - they're tool cabinets sold by Sargent in their 1911 tool catalog, on the Rose Antique Tools web site, shown with suggest content:
Single Door
Double Door
Warning - they are kind of big graphics files...
Leif
Norsewoodsmith.com
Re: Sargent V-B-M Tool Cabinet - 1911
>Thanks for the pics, Leif. Do you happen to know the tool just to the left of the marking gauge in the double door cabinet? Looks like a chunky little handle with a metal chuck or something on the end - ?
>"Do you happen to know the tool just to the left of the marking gauge in the double door cabinet?"
Looks to me like a No. 100 Lock Screw Driver
Catalog Page
QUOTE:
_______________________
No. 100, Lock Screw Driver, square shank for 3/16, 5/16, and 3/8 inch hubs, highly finished rosewood handle, polished steel ferrule and burnt black rustless finish on shank. This Driver is 4 inches long ; the shank being 1-9/16 inches up to the knurled portion of the ferrule. This Driver is a convenient tool for the pocket. The shank is held in the ferrule and handle by means of a rivet.
___________________________
UNQUOTE
My best guess, anyway. I would be quite sure that the large majority, if not all, of the tools in the cabinet are examples of Sargent. Would make sense from a marketing perspective.
Paddington Bear
>Andrew,
Is that the much sought after Paddington Teaches Shop Math book? ;~)
Todd O.
Ah yes
>and how do we get through a day in the shop without one of those, eh?
Now I've stopped laughing
>The real reason was I had to glue the thing back together after my 2yo attacked it.
I came up with a whole other stack of titles.
Let's just stick with Paddington Bear gets a hangover - it's probably one of the least offensive.
At least someone noticed. (I didn't until it was too late)
Cheers,
Andrew
