ADVERTISE HERE - FREE TRIAL
screwbox
screwbox
Jack Guzman from Maine
screwbox
>I made my first wooden screw today. I got a screwbox and tap from a used tool dealer I know. I turned a straight,knot free piece of hard maple to the right diameter.Then I held the shaft in my vice and threaded it using the screwbox.The tool worked good but I ended up with chipout on two opposite sides.I assume it's from grain runout.
Is there a better wood for this?Is there a way to avoid chipout in the species I'm using? Does anyone know of a tutorial on this subject on the web? How about a good book on the subject?
BTW the screw size is 7/8".I tapped a mating thread into a block of the same wood and the screw works fine with no binding.I'm excited. When I get this down pat I'm going to be making screws for all kinds of gadgets. Now I need one of those big screwboxes with the double cutters.
thanks,
Jack
Re: screwbox
Jim in Burlington Ont.
Re: screwbox
Jim in Burlington Ontario
>There was a Roy Underhill episode on a couple weeks ago but I didn't get to watch the whole thing. Apparently ever so slightly green maple seems to work best I think he mentioned 12-13 percent moisture was the best trade off.
Re: screwbox
Re: screwbox
>I wonder if wetting it would help.
Re: screwbox
Re: screwbox
Ted Shuck
>Wetting would probably help, but may make problems for your screwbox. I have use BLO to moisten dowels before using my (made in Taiwan) screwbox, and it does help.
Ted
Re: screwbox
answer my own question *LINK*
>I did a little more searching and discovered a very well done write up on the subject at Stephen Shepherd's website. ilovewood.com
Alburnam's archive
Re: screwbox
Re: screwbox
>Thanks,I'm going to try that. ---Jack
